Ordered GF2 Pro 64mb DDR-tips for the card?
oc jason
Senior Member
Fayetteville, AR
well i got it-so what are the overclocking programs that i can use for it- is it possible to make it a QUADRO card- that would be he way to go correct? also what would be a good set of drivers the WHQL 12.41? I just want any pertinent info. Its a Leadtek with 5ns ram 200/400. Should i change out the fan or HS for a better one(ill definately lapp the HS and use AS2), opinions please---pros/cons
[OC] Jason (Jul 16, 2001 10:54 p.m.):
Good card.
Quadro Yes
12.41 good, I've had no problems with the 12.90 though...
Changing the HSF may or may not help, probably not worth it as Leadtek is one of the better card manufacturers.
Now i doubt that ill do the Quadro hack i hear its for graphics proggies and will actually slow down gaming. i guess ill try 12.40-12.90drivers and see what get the best 3dmark score-i think ill leave the HS along unless i get problems or afre unhappy with it-maybe just change the fan out for a 60mm-i dont wanna risk prying the HS off the apply AS2- its not worth the risk to me-but my case is kinda hot?
[OC] Jason (Jul 17, 2001 11:22 a.m.):
Yes you can hack that card, it will not change gaming performance by much. It does unlock CAD functions that games never use.
