- Sep 5, 2001
Over the years, I've changed cases quite a few times. Each time, the cases NEVER had their sidepanels on, wires hanging out ghetto rigging things...etc They just look plain bad. One of my friends even said my rig looked as though it had been disemboweled (especially since i started WC'ing). Now I know looks aren't everthing, but just once, I would like to have a case that keeps its side panels on. So on black friday I picked up a P180. From here on out, I'll let pix do the talking.
Current setup (in all its "ghettoness")
I know it looks really bad, you need not remind me
Anyway, on with the modding
Objectives
1) Non-ghetto WC using top mounted Thermochill 120.3 & 6 Deltas wired to run 7volt
2) Clean Wiring
3) Removable dust filter tray below rad
4)Covering rad with honeycomb mesh (pending availability of mesh)
5) Obtain fan controller with enough cajones to handle 6 deltas
6) Switch to turn off 3 of the deltas when watching movies or something like that (optional)
7) Powder coat entire case (gun metal color) (optional, depending on cost)
I didn't take any stock photos of the P180, if you don't know what it looks like. here it is
First up, I had to remove the top fan and use a 8-32 bolt (had to drill the shroud to fit)
Shot of the delta AFB1212VHE
Test mount of the delta
Semi finished rad mount. the center fan will not be supported by bolts, but instead just screwed directly into the shroud.
Those are colder quick disconnects from mcmaster btw
After looking at it, I'd like the rad to sit higher. I'm going to change out the 1 3/4" bolts for 3" bolts. Also, the deltas are configured to be blowing upwards.
I'm also not sure if these thermochill "shrouds" cut it still looks like there would be big dead spots.
Pump placement is still undecided as well. If anyone has any suggestions on pump placement or shrouds. I'd appreciate it.
Hopefully more updates to come this weekend.
Objectives
2) Clean Wiring
