Outpost.com 17" Flat-panel $299 AR
AC Slater
Spokane
50ms is very slow. This would be fine for an office but I wouldn't touch it for gaming, it would be ghosting city.
NeoGeo
NeoGeo
NJ
How bout this LCD, only $20 more and the response time is 1/2 the outpost.com LCD!
Is $320 a good price? Anybody ever heard of that brand, tigerdirect says it comes with a 3-yr warranty, that's pretty good right there:)
Maxvla
Senior Member
OKC
very nice on the 2nd one. its got nearly the same specs as the Benq that i was looking at for 378 and 30$ rebate.
NeoGeo
NeoGeo
NJ
Should make a decent AIW-TV/web-browsing monitor right?
Maxvla
Senior Member
OKC
well you gotta figure in shipping too.
its 20 bucks for them to mail that to you.
the benq has 16ms response time which is better than that ones 25ms. 25ms is still pretty good but 16ms is even better.
it works out to be 339 shipped for that one and 348 shipped for the benq. 9 bucks more for the better monitor. i think i'd splurge a little.
Maxvla
Senior Member
OKC
Doomer87 said:
The 2nd one has less resolution
um.. where do you see that?
both monitors do 1280x1024 @ 75hz
the benq has a 500:1 contrast ratio compared to the 300:1 for the outpost one. the higher the better.
NeoGeo
NeoGeo
NJ
Where can I find this Benq LCD? I think I just might dig deep and splurge:D
AC Slater
Spokane
Only downer about the 2nd one is there is no DVI connector. If you ever get an LCD make sure it has a DVI connector! The difference between DVI and VGA is like night and day.
Maxvla
Senior Member
OKC
the 1st one doesn't either
:confused:
Input Connector: 15Pin D-sub High Density Connector for Video & Sync Signals
NeoGeo
NeoGeo
NJ
DVI and VGA are good for now, I guess. I'm holding off on getting a >17" flat-panel for gaming until they make them w/ OLED and an interface with more bandwidth than DVI...by that time some good PCI-Express/64 graphics card should be out. VGA shouldn't be that bad for TV and web browsing.
Maxvla
Senior Member
OKC
by that time there will be something just on the horizon. then you will want to wait for that.
when does it end?
Demont
when does it end?
Well, display interfaces don't exactly have a 6-month product cycle like a video card or something. I doubt anything will be on the horizon for a while after this next generation. I mean, how long did it take to go from VGA to DVI and now from DVI to whatever-it-is? A long time.
