My Pc specs
AthlonXP 1900
Epox8K7A
512mb Crucial PC2100 (2x256)
40GB Maxtor 7200 rpm
SB Live 5.1
128mb GF4 Ti4600
16x TDK CDRW
I just dont see how people are constantly hitting such insane fsb speeds.
I can get my setup to do 12x150=1800 but its not stable at all, itll lock up after a few minutes under load.
I used to have a 1.4 tbird & I could set the multiplier as low as I wanted but Id never get over 150fsb.
Im currently running my Athon XP at 12x145=1740mhz without problems.(yes its still multiplier locked)
My question is, I dont know exactly how to tell whats crapping out on me at higher fsb speeds.
How do you determine if its the ram, hdd, video or anything else not liking the higher fsb speeds?
Im currently shopping for a DDR333 mobo & new ram.
Most DDR333 mobos I see are allowing OCing of ram speed while leaving PCI speeds at default, so that may help.
(PLEASE PLEASE tell me if that interpretation is correct, ive never been quite sure)
However most DDR333 mobos only support a maximum of 1.85v for the cpu.(epox is the only board ive seen go higher)
Right now..
Ive gotta run 1.95v to get over 1740mhz.
Which brings up another question.
If I unlock my cpu & use a lower multiplier & higher fsb, does this eliminate the need to up the cpu voltage vs the ram voltage?
In other words, if Im stuck at 1.85v & my cpu will only do 12x144 at that voltage.
If I wanna go higher..
I would use a lower multiplier & higher fsb , does this eliminate the need for a higher cpu voltage and I can stabilize my OC with DDR voltage instead?
AthlonXP 1900
Epox8K7A
SB Live 5.1
128mb GF4 Ti4600
16x TDK CDRW
Right now..
