Overcking the Tbread "B"
wuzzapiman
I have a 2400+ AIUCB "9" week 43
is this a good OC'r
right now i have it @ 12x166 with 1.7Vcore on my cheap temperary heatsink (sealing pump).
Idle 42
Load 45
What steps should i take to OC it further?(will be on watercooling)
Abit AT7-MAX2
Corsair XMS PC3200 Cas2 @ 2-2-5-2
TC
Senior Seti Addict
Denver, CO
I've got the exact same one - same week et al. Mine will post at 2400 with default voltage, but so far will only run stable at 2200 with default voltage. I'm using a thermalright sk7 and temps hover around 40C under load. I'm going to try bumping it up in a day or two. I'll be happy if I can get at least 2300 stable, maybe 2350. Anything beyond that would be gravy.
EluSiOn
SC, USA
I have a week 42 same stepping.
I am able to get to 2285 mhz but find best benchmark at 149*15. Getting water cooling system now and hope it will get it to 2400 mhz (after I change my mobo).
You might want to increase both your VCORE and Vdmm to 1.85/3.00
