overclock my steam driven hunk of junk
redeye
have a fujitsu p2 233mhz with a frustratingly restrictive bios, any one advise how to clock or tweak without using bios (recommend software perhaps)
also graphics card is an ati 3d ragepro agp2x
any ideas how to improve performance?
appreciate any help
thanks
Do you have a manual detailing any jumper positions for different FSB's or multipliers on the motherboard. You may find a diagram on the motherboard itself.
If not there is always Soft FSB available from http://www.H-Oda.com but this would require you to identify the PLL chip on your motherboard and there may not be a patch file for it.
I think that jumpers are probably the way to go.
thanks for your help, no manual as bought second user.
had a quick scan of motherboard but no map and sparse jumpers without explanation( horribly unfriendly pc, but stable)
what do you mean pll chip and how can i find out which it is?
again thanks
