Overclock suggestions?
mr.radon
I've gotten the system stable to 3.24GHz, but was hoping some people might have suggestions. This is my first attempt to OC.
Am running the following:
GIGABYTE GA-EP45-UD3P V1.0/1.1
Q9400
OCZ Reaper HPC 8GB (4x2GB)DDR2 1066 (PC2 8500)
Vista Ultimate 64-bit
Code:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster .................[Auto]
CPU Clock Ratio .........................[ 8 X]
Fine CPU Clock Ratio..................... +0.0
CPU Frequency .......................3.24GHz( 405x8)
(401X8)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control...................[Enabled]
CPU Host Frequency (Mhz) ................[405]
PCI Express Frequency (Mhz) .............[100]
C.I.A.2 .................................[Disabled]
Advanced Clock Control [Press Enter]
CPU Clock Drive........................<<< 800mV
PCI Express Clock Drive................<<< 800mV
CPU Clock Skew (ps)....................<<< 0ps
MCH Clock Skew (ps)....................<<< 0ps
DRAM Performance Control
Performance Enhance......................[Standard]
Extreme Memory Profile (X.M.P.)..........[Disabled]
(G)MCH Frequency Latch...................[400MHz]
System Memory Multiplier ................[2.66D]
Memory Frequency (Mhz) ...................1080
DRAM Timing Selectable ..................[Manual]
Standard Timing Control
CAS Latency Time..........................   5
tRCD .....................................   5
tRP'......................................   5
tRAS......................................  15
Advanced Timing Control
tRRD.................................4...[Auto]
tWTR.................................4...[Auto]
tWR..................................8...[Auto]
tRFC................................72...[Auto]
tRTP.................................4...[Auto]
Command Rate (CMD) ..................0...[Auto]
Channel A Timing Settings
Static tRead Value..................10...[Auto]
 tRD Phase0 Adjustment...............0...[Auto]
 tRD Phase1 Adjustment...............0...[Auto]
 tRD Phase2 Adjustment ..............0...[Auto]
 tRD Phase3 Adjustment...............0...[Auto]
Trd2rd(Different Rank)...............8...[Auto]
Twr2wr(Different Rank)...............8...[Auto]
Twr2rd(Different Rank)...............7...[Auto]
Trd2wr(Same/Diff Rank)...............9...[Auto]
Dimm1 Clock Skew Control.................[Auto]
Dimm2 Clock Skew Control.................[Auto]
DDR Write Traing.........................[Auto]
Channel A Driving Settings
Driving Strength Profile.................[Auto]
Data Driving Pull-Up Level...............[Auto]
Cmd Driving Pull-Up Level................[Auto]
Ctrl Driving Pull-Up Level...............[Auto]
Clk Driving Pull-Up Level................[Auto]
Data Driving Pull-Down Level.............[Auto]
Cmd Driving Pull-Down Level..............[Auto]
Ctrl Driving Pull-Down Level.............[Auto]
Clk Driving Pull-Down Level..............[Auto]
Channel B Timing Settings
Channel B Driving Settings
Motherboard Voltage Control
>>> CPU
Load-Line Calibration....................[Disabled]
CPU Vcore.......................1.21250V.[1.22500V]
CPU Termination.................1.200V...[Auto]
CPU PLL.........................1.500V...[Auto]
CPU Reference...................0.760V...[Auto]
>>> MCH/ICH
MCH Core........................1.100V...[1.20V]
MCH Reference...................0.760V...[Auto]
MCH/DRAM Ref....................0.900V...[Auto]
ICH I/O.........................1.500V...[Auto]
ICH Core........................1.100V...[Auto]
>>> DRAM
DRAM Voltage....................1.800V...[1.900V]
DRAM Term.......................0.900V...[Auto]
Channel A Referance.............0.900V...[Auto]
Channel B Referance.............0.900V...[Auto]
Advanced Settings
HDD S.M.A.R.T. Capability................[Enabled]
Limit CPUID Max. to 3....................[Disabled]
No-Execute Memory Protect................[Enabled]
CPU Enhanced Halt (C1E)..................[Disabled]
C2/C2E State Support.....................[Enabled]
x C4/C4E State Support...................[Disabled]
CPU Thermal Monitor 2(TM2) ..............[Enabled]
CPU EIST Function........................[Disabled]
Virtualization Technology................[Disabled]
Init Display First.......................[PEG]
Integrated Peripherals
SATA Port0-3 Native Mode.................[Enabled]
Azalia Codec.............................[Auto]
Onboard Serial Port 1....................[Disabled]
Onboard Parallel Port....................[Disabled]
Parallel Port Mode....................... SPP
Legacy USB Storage Detect ...............[Enabled]
Power Management Setup
ACPI Suspend Type........................[S1(POS)]
Soft-Off by PWR-BTTN.....................[Delay 4 Sec.]
PME Event Wake Up........................[Disabled]
Power On by Ring.........................[Disabled]
Resume by Alarm..........................[Disabled]
HPET Support.............................[Enabled]
HPET Mode................................[64-bit mode]
Power On By Mouse........................[Disable]
Power On By Keyboard.....................[Disable]
KB Power ON Password.....................Enter
AC Back Function.........................[Soft-Off]
PnP/PCI Configurations
PCI1 IRQ Assignment......................[Auto]
PCI2 IRQ Assignment......................[Auto]
Lian-Li PC-A77B Case
OCZ Z Series Gold 1000W PS
Q9400
(2) Samsug 1.5Tb HD in RAID 1 (OS)
9650SE-16ML RAID Card with BBU running
(16) Western Digital Caviar Black WD7501AALS 750GB 7200 in RAID 6
(3) AMS DS-3151SSBK Backplanes
EVGA GTX 280 Video Card
(1) 28" (1900 X 1200)
(1) 21" (1680 X 1050)
redduc900
Inactive Moderator
Portland, OR
Give these settings a try for 3.4GHz...
Code:
CPU Host Frequency (Mhz) ...............: 425Mhz
PCI Express Frequency (Mhz) ............: 100Mhz
C.I.A. 2
CPU Clock Drive..........................: 800mv
PCI Express Clock Drive..................: 900mv
CPU Clock Skew (ps)......................: 150ps
MCH Clock Skew (ps)......................: 250ps
Performance Enhance....................: [Standard]
Extreme Memory Profile (X.M.P.) .......: Disabled
(G)MCH Frequency Latch.................: [333]
System Memory Multiplier ..............:2.40B
Memory Frequency (Mhz) ................: 1,020Mhz
CPU
CPU Vcore..........................: 1.30v
CPU Termination..... 1.200V*.......: 1.24v
CPU PLL....1.500V*.................: 1.54v
CPU Referen.....0.755V*............: 0.76
CPU Reference2,,0.800V*............: 0.81
MCH/ICH
MCH Core.....1.100V.................: 1.20
MCH Reference..0.800V...............: 0.81
MCH/DRAM Ref.......0.900V...........: 0.91
ICH I/O.....1.550V..................: 1.556
ICH Core...1.100V...................: 1.14
M
mr.radon
Thanks, I'll give that a try. I got her stable at 410 last night, tested with no hang ups. Anything higher she hung. Will try those settings.
Thanks for the suggestions.
M
mr.radon
Wow! Thanks for those settings. Do you run the Q9400 chip too? Where did you get those?
Just got done with a few quick tests, checks out fine. Will let the memory test run overnight. I adjusted some memory settings.
Is there a forum site for OC settings based on chips? Someone should create a database a valid OC settings per chip/memory.
New settings:
Q9400
Code:
CPU Frequency .......................3.40GHz( 425x8)
Clock Chip Control
CPU Host Frequency (Mhz) ................[425]
PCI Express Clock Drive................<<< 900mV
CPU Clock Skew (ps)....................<<< 150ps
MCH Clock Skew (ps)....................<<< 250ps
(G)MCH Frequency Latch...................[333]
System Memory Multiplier ................[2.640B]
Memory Frequency (Mhz) ...................1020
tRRD.................................4...[3]
tWTR.................................4...[3]
tWR..................................8...[6]
tRFC................................72...[54]
tRTP.................................4...[3]
Command Rate (CMD) ..................0...[2]
>>> CPU
CPU Vcore.......................1.21250V.[1.30000V]
CPU Termination.................1.200V...[1.240]
CPU PLL.........................1.500V...[1.570]
CPU Reference...................0.760V...[0.755]
>>> MCH/ICH
MCH Reference...................0.760V...[0.825V]
MCH/DRAM Ref....................0.900V...[0.910V]
ICH I/O.........................1.500V...[1.570V]
ICH Core........................1.100V...[1.100V]
>>> DRAM
DRAM Voltage....................1.800V...[1.96V]
Advanced Settings
Q9400
