Overclockers of 9600gt
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Base info???
Just overclock your card!
Here are some pointers:
* Keep it under 80C or so
* Unlink shaders from core and overclock each on their own, finding the maximum for each indivdually.
* Use furmark stress test in a window to check for artifacts while raising the c/s/m.
* EACH CARD WILL OVERCLOCK DIFFERENT! So having other people's information will not necessarily help you out!
NOW GO! Overclock that bad boy until she artifacts then back her down a bit and go from there!
KonaKona
Trashcan Man Member
I think mine is stock at like, 675/1000 or something. I distinctly remember not being able to OC mine very much. :(
