- Aug 26, 2012
- TN, USA
Hey guys im back When i first setup my pc i came here looking for advice to oc it. im back to get help oc it since everyting is upgraded :3
So the originall post was at http://www.overclockers.com/forums/showthread.php/715422-3570k-ivy-bridge
Now ill give you my specs and i need help ocing this beast to the highest stable oc but not surpassing 80c. I will need detailed help tho :/
Case: Nzxt H400
Motherboard: Gigabyte ga-z77-udth5 (gigabyte uefi on f12 bios bversion) Rev 1
Cpu: 3570k
Cpu Cooler: H110 v2 at 4.2 sits at 30 idle (new)
Gpu: Msi gtx 1060 6gb oc to 2100 mhz (new)
Psu: Vampire Raidmax 700w (new So silent)
Ssd: Kingston 120 gb (for OS and cs:go)
Monitor: Benq xl 144hz
Hd: 5400 Rpm 500gb Wd 3.5 inch (from laptop)
Fans Stock with cooler case and bought 2 pressure af140 corsairs
ram ddr3 1866 corsair vengenace (removed heat spreaders Due to clearance for a air cooler in 2012)
Any help will help but i use my pc for gaming when i do use it but i would like it to be able to power into sleep mode aswell...
If i can just get help with a list of stuff on my bios that needs to be set like llc (turbo)
EDIT: When i try oc myself it wont go past 4.1 ghz im sure i have a setting messed up but idk.
Case: Nzxt H400
Cpu: 3570k
