- Oct 30, 2002
- New Jersey
This board has a divisor of 5 correct? The max safe speed for PCI cards is 33 mhz, and 166/5 = 33.3 mhz, so technically that would be the safest PCI speed.
However, does the KT400 have a divisor of 5 as well as the KT333, or a divisor of 6? I have NO PCI cards in my machine, everything is onboard, and then there's USB 2.0. Would I beable to overclock my FSB past 166? How is my hard drive affected by this?
warlo ckf: im gonna OC my comp
warlo ckf: so im gettin
warlo ckf: SLK-800 Heatsik w/ Sunon Ultra Quick 80 mm Fan @ 50 cfm, about 43 dbA, w/ arctic silver 3 thermalpaste, and 2 regular case fans - sunon 80 mm @ 36 cfm,
All of that + 3 day fed ex shipping is about 75 bucks. I was wondering if my temperature would drop from idle 44c to about 20c using all of that. I'd have 4 case fans, and the heatsink w/ the fan.
do you think I would need a shim to use with that heatsink? What does it do?
