- Oct 3, 2003
- Kansas City
I am pretty new to overclocking.. When I built my computer a year ago I overclocked my CPU to 2.85GHz with stock cooling. I am now wanting to overclock it a bit more to get over the 3GHz mark.
Here are my current settings:
ext clock = 148mhz
pci/agp freq = locked at 33mhz
multiplier = 19x (do not change or it wont post)
fsb freq h/w strap = low
dram ratio = 3:4
What would you guys suggest for me to get (cooling-wise) to allow me to reach the 3GHz mark? As far as case fans go, I just have a front case fan and that's it. Also, what settings would I have to use to achieve that clock speed? Does anyone else have my setup running stable over 3GHz? If so, what cooling are you doing?
I also have an ATI Radeon 8500 LE video card. The stock fan went out a couple months after I built my pc. I have been having problems with it crashing all the time.. which I assumed was because it was overheating. I just bought a Vantec Iceberq 4 to replace the broken fan. Are you able to overclock video cards? With the cooling I will be getting from the Iceberq 4.. I figured overclocking it would be an option.. but I wanted to see what you guys thought. Should I overclock it too?
Any help would be much appreciated?
ext clock = 148mhz
dram ratio = 3:4
