- Mar 1, 2019
- China
Dear All,
Greetings of the day. I need some help on overclocking my Threadripper 2950X. Hope to find the same here. Before I put out my doubts and observations here is my base system:
Motherboard: MSI X399 MEG CREATION (Bios Version:7B92v12 (latest version as per manufacturers website))
CPU: Threadripper 2950X
RAM: 64GB(8 X 8GB) DD4 2933 MHz Gskill TridentZ CL14
HDD: 2 * 1TB M.2 NVME SSD, 1 * 1TB SSD
GPU: 2 * RTX 2080 Ti FE (In NVLink Config)
Cooling: Custom Water Cooling, 2 Radiators (420MM + 280MM)
PSU: 1200 Watt Cooler Master V1200 Platinum Standard
I believe I have a good & a powerful workstation with me. I would like to Overclock my processor and see how far can I push my system and get the maximum speed out of it as I think I have a good enough cooling system. Now I tried a tweak by going to the bios and adjusting the CPU Ratio to 42 from the default 35 and increasing the Core Voltage to 1.4125, now the system apparently works fine but as soon as I run Firestrike 3D TimeSpy benchmark initially I get a blank screen but may be after a couple of minutes the screen resumes normal. Now my questions are:
1. Am I doing something wrong here?
2. Can I actually Overclock this system?
3. Is there something called Turbo Boost on this motherboard for this CPU and if yes then how do i activate it. I have seen videos of some people setting Base clock of 1950X (Not 2950X) to 4.1 and getting a Turbo Boost of 4.9.
I am new to Overclocking and still don't understand a lot about it and thus would request you guys to please help.
Cheers
Sajeev
Cheers
Sajeev
