Hi there,
Does the ASUS A7M266 supports changing the multiplier of an unlocked CPU (in my case tbird 1333 AXIA Y) trough bios.
The multiplier is now colored white in my bios and can not be altered.
If anyone has experience with that please respond.
I can already overclock stable to 146Mhz FSB till 1460 Mhz with 1,75V core,
bios turbo mode, swiftech MC462 revA (with sanyo denki fan).
Loaded temp is about 38/39 degrees. And i am using a front mounted with hole 12 cm 230Volts fan (it really rocks) a smaller 8cm also in the front and two 8 cm fans in the back. For the rest also 4 X 4,5 cm fans for HD cooling that also blow in some air.
Greetz,
TBiRDIE
Greetz,
TBiRDIE
