Hi everyone!
A friend who upgraded his rig just gave me 8Gb DDRAM2 at 1066Mhz, and I know my Quadcore q660 does not need that high of frequency but I won't look a gift ram in the mouth
Anyways, my system is getting on in years and I'd like to squeeze more power from it and jump my 2.4 Ghz to 3.2 or more. I know a bit of the basic principles of overclocking but not that much. So I really need help.
First, am I gonna be able to have a 1:1 ratio? it would mean having a 533Mhz FSB if I'm correct, multiplied by 6 instead of the native x9 multiplier. Is this possible or do I need to settle on a 350+ and have a screwed up ratio? Those CPU are supposed to work well asynchronous if I read correctly somewhere.
If I have to settle to a lower FSB (on a overcloking guide some guys put their q660 at 372 but on a different mobo) do I need to underclock my memory or do I leave it as is? Any road, how do I do it?
Secondly, voltage, which ones should I set manually and to what amount? CPU, PCIE, RAM voltages?
Finally, any other things I should change on the BIOS settings?
My rig:
Asus P5q Deluxe
Quadcore Q660 2.4GHz 266 FSB G0 step
Power Cooler GX 750watts
Kingston HyperX PC8500 4x2g 1066Mhz
I know it's a tall order guys, but if someone could give me a good answer I'll be really grateful, I know you guys are all up in your i7 right now but have a thought for the poor guys who can't afford them yet
My rig:
Asus P5q Deluxe
