The old Athlons with external cache have the speed of the cache set to 1/2 the speed of the CPU. This is not fixed, but dynamic, so it you have a 600mhz cpu the cache runs at 300mhz, if you overclock the cpu to 700mhzm than the cache MUST run at 350mhz, at 800mhz cpu clock the cache MUST run at 400mhz, this is the main contributing limiter to the old Athlon as the cache could simply not take the speed, otherwise AMD would have put 400 and 500mhz SRAM 2nd level cache in them, but one they past 700 or 750mhz the cache divider was set to 1/3 the speed of the CPU. This is the instability of the old Athlon line and the crippler that did not allow the old Athlon to really enjoy the speed increases as much as they should have. Kinda feel bad for AMD, if they could have gotten the Tbird to the market 6 months earlier with the internal cache, Intel would have in no way enjoyed the sucess of the Pentium III as much as they had.
