overclocking and storage issues
enhanced
Fairbanks Alaska
ive been into overclocking ever since i first got into computers 10 or so years ago. back then only some motherboards offered a feature called "pci lock" or something similar which would lock the pci bus at 33/66/100mhz while overclocking. this helped keep data from becoming corrupt when written to the hard drive.
the questions i have are, does Sata have this same issue with data being corrupt? what about USB?
i have never seen this lock feature on any newer motherboards and have never really had a problem until recently. i have a system thats overclocked and as a fairly large amount of data on it. (right around 1TB) and some of the data has become corrupt. The drives are running on Sata which is why i asked. would usb offer some protection from this? in the form of an external USB drive?
thanks
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
That lock feature is certainly there for PCIe...its on my board. I do not beleive the USB ports will have a corruption issue, no. Actually, I havent seen sata have that issue either... maybe b/c I put the pcie locks on? Not sure.
ThePerfectCore
Red Raccoon Dojo
Texas
It's nearly impossible to find a motherboard now that DOESN'T lock the busses. I think your data corruption problems stem from elsewhere.
E
enhanced
Fairbanks Alaska
the system in question has a DFI lanparty UT 3200 cfx and I can not find any pcix lock, the only thing i found that maybe close is a PCIx common clock.
another system i have which was built around the same time has a PCIE spread spectrum and allows you to adjust the pcie clock. default is set to 100mhz.
