Hi all ,
Im new to this forum and fairly new to overclocking any advice would be much appreciated
. Specs first then what ive pushed this system to already :
Asus A7V-266-DDR Motherboard Rev:1.06 Bios 1002
Athlon Thunderbird 1.4 Ghz 266 AXIAJ Unlocked
2 x 256 Crucial DDR Memory cas 2.5
Asus V8200 Geforce 3
Soundblaster live 5.1 platinum
IBM 60 GXP 40.1 Gb Hard drive
Plextor 16/10/40a + Toshiba 16 x DVD 48 x CD
Network Card
AMD approved 300 watt psu
ThermalRIGHT sk6 h/s+f
Coolercase Tornado 6 fans
Windows ME
Temps : Warm at the moment in UK
CPU Idle 46 load 53
MB Idle 23 load 28
Every thing on the board is in jumperfree mode . System is set at 10.5 x133 .
This system is rock stable at 11.5 x 133 sisoft reports it at 1.55Ghz only slight increase in temps
If i try 12 x133 the computer posts and updates but hard drive wont spin for windows and system shuts down
If i try 10.5 x 133 and increase the fsb i cant get it past 141 fsb anything beyond that causes windows protection error .
Im sure this system will be very stable at beyond 1.6ghz just not sure of the right way to do it , any advice from someone with this motherboard or general advice , would be much appreciated thanks
Network Card
Windows ME
CPU Idle 46 load 53
MB Idle 23 load 28
