overclocking athlon 2000XP
nokiaXP
malaysia
can anyone show your overclocing result on athlon 2000XP including what heat sink,thermal paste u r using and the idle and load temp.thanks a lot
Ambiguous
Chicago,Illinios
iam using a 2000+ its overclocked to a 2200+ at 1.79ghz i have a volcano 9 coolmod and using artic silver3 heat compound, my idle is around 43c and my load is around 46c, hope this helps.
OC Detective
Mauritius
Details in my sig using AS2. Idle temps around 40c and load around 48c - if I have the air con on the temps drop by about 5c
