Hi, I'm new to overclocking and want to overclock my rig.
I can overclock my CPU from 3GHz to 3.6GHz by upping the FSB from 333 to 400MHz using Easy Tune 6. FSB/DRAM timing is 1:1. The Ram then running at 400MHZ (effectively 800MHz) No Voltage changes are required. Machine very stable using Prime 95 and temp never goes above 53 Degrees Celcius.
The problem is that I want to do this in the BIOS and not use easy tune 6 every time the computer reboots. Below I'll list some BIOS settings as they are standard and then what I'm changing them to. When I change these settings in BIOS the machine restarts doesn't POST and just reboots again allowing me to go into BIOS again and then my changes are gone again.
Advanced BIOS Features
C1E - Enabled I leave this on
CPU Thermal monitor - Enabled
CPU EIST - Enabled I leave this on
MB Intelligent Tweaker
CPU clock Ratio - 9X I leave this as is
CPU Host clock control - Disabled I change this to enabled
CPU host Frequency - 333 I change this to 400MHz
PCI-E Frequency - Auto I change this to 100MHz
System mem multiplier - Auto I change this to 2.0 to give 800MHz
System Voltage Control - Auto I leave this on auto but have tried to manually set it to 1.225V also as it should be for this clock.
These settings seem right to me but I don't think the machine is Posting.
I have also tried to disable C1E and CPU EIST speedstep and throttling.
The BIOS has been flashed with Q-Flash to F3 and Optimized defaults were loaded afterwards.
I don't know why I can overclock the machine with Easy tune 6, but simply can't do it in the BIOS. Am I doing something wrong?? Pls any advise would be appreciated!
