Overclocking Corsair XMS4000 ram on IC7-MAX3
remkinu
Trying to overclock my system and having difficulty determining maximum settings for overclocking. Appreciate any advice.
- Abit IC7-Max 3
- P4 3.2 GHz (800fsb)
- Corsair Twin XMS4000, 1024 MB (2 pairs of twin512MB)
- 2 - 36GB Western Digital Rasptors in RAID 0
- ATI Radeon 9700 Pro
- Lian Li aluminum case with 3 - 80mm high speed fans
- Swiftech CPU heatsink/fan
- Antec True Power 480
Many thanks
BaldHeadedDork
Welcome to the forums!
What version of XMS3200 do you have?
The older v1.1 sticks use the Winbond BH5 memory chips and overclock pretty good for what was a first-generation low-latency DDR400 chip. (Long way of saying the newer PC3500+ memory overclocks from the default PC3200 speed better than the v1.1)
But the later versions of XMS3200 used BH6 chips and they sometimes had problems running at the stock speed on 875P boards, regardless of how loose the timings were. A lot of people who bought XMS in anticipation of how well it worked on 845 boards had a bad surprise when the Canterwood and Springdales came out.
Check your heatspreader for a sticker showing the revision of the memory. If it's anything but v1.1 you're going to have a hard go getting that memory above 200MHz.
BHD
R
remkinu
Ram is Corsair XMS4000, native settings atr 3-4-4-7, 200 MHz per SiSoft Sandra.
Thanks.
Lance
Sirius
S.C
I have xms4000 and I am at 240fsb at 2.7vdimm, timing 3-4-4-6,1:1, GAT-auto,auto,auto, disable, disable. I cant post with lower timing.
