- Dec 14, 2010
Well, when my 4000+ San Diego E6 turned out to be overly disappointing I figured I would see if the ClawHammer chip I had here could do any better.
Upon booting up I suddenly realized I still had it manually set up in the bios for running with the other CPU and the voltage was set at 1.35V as opposed to the default 1.5V of the ClawHammer. To my surprise though, it made it through POST just fine with the incorrect voltage setting, and even made it to the desktop.
So, out of curiosity of whether or not I could run it at this voltage and be stable I fired up Prime95 and CPUID HWMonitor so that I could monitor the temps during the test. To my amazement it seems to be completely stable, making it through 30 minutes on the blend test, during which it only inched its way past 40°C once and stayed below 40°C the rest of the time.
I have to ask, has anyone else ever ran a ClawHammer chip this far below its rated voltage, or is this uncommon? Were the AMD engineers just really generous when it came to the voltage on these and were they giving it more than necessary just in case it needed it?
It's actually still running as I type this, and everything seems perfectly normal.
Looks like a nice chip so far, with idle temps of 28-33°C and load temps of 34-41°. I must say I really had to try hard to get this chip to go over 39°C, it stayed under 40°C for over twenty minutes of Prime95, and never broke the 40°C barrier during multiple passes on SuperPi 1m, and several UCBench 2011 runs. I have to say from a temperature standpoint it is very nice (and encouraging) to find a chip that runs this cool at full load.
