- Dec 14, 2010
This CPU was very disappointing.
It doesn't overclock well, it takes a lot of voltage to get to its max (and isn't stable at its max speed), and it produces as much heat as one might expect from something like a nuclear reactor. This thing runs just ridiculously hot.
Athlon 64 X2 3800+ Windsor overclock settings
2.0GHz (stock): 1.15V (1.10V)
2.2GHz: 1.22V (1.175V)
2.3GHz: 1.26-1.28V (1.225V)
2.4GHz: 1.33V (1.28750V)
2.5GHz: 1.45V (1.40V)*unstable at any voltage
It hit load temps of 82°C on Core 0 and 88°C on Core 1 with Prime95 running (according to Hardware Monitor and Core Temp) when I was at 2.5GHz with 1.45V.
I'm wondering if there's some issue with the thermal material between the Core and Integrated Heat Spreader that is causing the thermal issues. I think they used solder on these CPU's, but might have been some form of thermal paste/thermal material? I remounted the heatsink and replaced the paste a few times, but it didn't help.
