Overclocking EVGA Titan X Hydro
MatuX
Hey guys!
EVGA Titan X Hydro Cooper: http://www.evga.com/Products/Product.aspx?pn=12G-P4-2999-KR
I managed to get to:
GPU Clock: 1242 MHz (+90 MHz)
Memory: 1978 MHz (+450 MHz)
Boost: 1331 MHz
Cranked voltage to +112mV, Kboost on, power to 110%
The GPU clock peaks at 1470 MHz, voltage 1.243v and temperature 58c.
GPU-Z's PerfCap Reason states VRel, VOp and at times Pwr.
I've held this for two hours of 3DMark's Fire Strike Ultra, 'Graphics test 2' on a loop.
What I'd like to understand is why I can still hold this test for 2 hours with no stability issues with +15 MHz more on the GPU and +50 MHz on memory. But when I try to run the standard Fire Strike Ultra benchmark, my computer gets a black screen almost immediately if I try to go any higher than what I stated in the beginning.
Also, am I exceeding my card's capacity in a way that I could damage it or highly reduce it's lifespan?
Thanks!!!
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
VRel is likely normal...
VOp is not and is likely causing throttling... if that isn't the Pwr is. Back off on the voltage and clocks a bit so you can sustain the boost clocks.
M
MatuX
Thank you so much for the info, EarthDog! Super useful.
I've seen how the GPU clock fluctuates during heavy usage and I infer this is my card being effectively throttled.
I've taken a step back and went down to 1202/1291 (Clock/Boost) and +49mv for a total of 1.205v, which gives me an (almost) sustained 1404 Mhz clock.
I've seen it throttle down at some points, GPU-Z reports "Pwr" at those moments.
I take this is an indication that there's effectively not enough power to power the GPU. Tautology apart :). Which means I should consider either raising the voltage or reducing the GPU clock's offset. Is this assessment correct?
Thanks a lot :)
EarthDog
Buckeyes!
Ithe is for the power limit. Once you hit a certain level, which you can raise in msi afterburner, it will lower the clocks.
JrClocker
AKA: JrMiyagi
If you are hitting the power limit, your only real choices are:
(1) Reduce the voltage (how low can you go???) to get less power draw, and hopefully more MHz
(2) Get a modded BIOS that lets you increase the power limit for the card
