Hello. I've been running this for half a year with no problems but sometimes it resets to normal after restarts. Can i fix that? Also i wanted to check if it needs any more tweaks to improve and stabilize. Need some help with memory timings if someone knows whats up.
PC SPECS:
MB_____________________GIGABYTE P35-DS4 Rev. A2 (LPCIO - ITE IT8718)
CPU____________________Intel Core 2 Duo E6750 @ 2.66 ghz
SMBIOS__________________ 2.4
BIOS____________________ Award Software international Inc. F14 (Date 06/19/2009)
RAM____ ________________DDR2 - 2x 1GB Kingston HyperX (333mhz) + 1x 2GB kingston ( 333-400 mhz)
Graphics_________________ NVIDIA GeForce GT 730 ddr3 2gb
BIOS SETTINGS:
Robust Graphics Booster_________________ [Fast] ?
CPU Clock Ratio ________________________[8x]
CPU Frequency _______________________3.20 GHz ( 400x8)
CPU Host Clock Control________________[Enabled]
CPU Host Frequency(Mhz)______________[400]
PCI Express Frequency(Mhz)____________[100]
C.I.A. 2_____________________________[Disabled]
Performance Enhance________________[Standard] ?
System Memory Multiplier____________SPD_[2.00]
Memory Frequancy(Mhz)_____________667___800
DRAM Timing Selectable_____________SPD__[Auto] ?
*****Standard Timing Control********
CAS Latency Time___________________5___ ?
DRAM RAS# to CAS# Delay___________5__ ?
DRAM RAS# Precharge_______________5__ ?
Precharge delay(tRAS)_______________15_ ?
*********Advanced Timing Control*********
ACT to ACT Delay(tRRD)______________3__Auto
Rank Write To READ Delay____________3__Auto
Write To Precharge Delay_____________5__Auto
Refresh to ACT Delay________________44__Auto
Read to Precharge Delay______________3__Auto
Static tRead Value___________________8__Auto
Static tRead Phase Adjust_____________0__Auto
*************SYSTEM VOLTAGE NOT OPTIMIZED********* (blinking)
System Voltage Control_______________[Manual]
DDR2 OverVoltage Control_____________[Normal] ?
PCI-E OverVoltage Control_____________[Normal]
FSB OverVoltage Control_______________[Normal] ? (
G)MCH Overvoltage Control____________[Normal] ?
Loadline Calibration___________________[Auto] ?
CPU Voltage Control___________________[1.35000V] ?
Normal CPU Vcore____________________1.35000V
PC SPECS:
BIOS SETTINGS:
