thanx for all this info
I was skeptical at first about overclocking but after reading these articles and applying the knowledge wrote in these forums.
I have achieved an overclocked machine.
to my suprize my first run was at 2.6g from a p4 2.4b chip now i have updated all my coolers and run at a respected 3.366gs
CPU-Z Report
CPU-Z version 1.21.
CPU(s)
Number of CPUs 1
Code Name Northwood
Specification Intel(R) Pentium(R) 4 CPU 2.40GHz
Family / Model / Stepping F 2 7
Extended Family / Model 0 0
Brand ID 9
Package mPGA-478
Core Stepping C1
Technology 0.13 µ
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 3371.9 MHz
Clock multiplier x 18.0
Front Side Bus Frequency 187.3 MHz
Bus Speed 749.3 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3371.9 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
Mainboard and chipset
Motherboard manufacturer
http://www.abit.com.tw/
Motherboard model IS7/IS7-G/IS7-E(Intel i865-ICH5), 1.0
BIOS vendor Phoenix Technologies, LTD
BIOS revision 6.00 PG
BIOS release date 11/04/2003
Chipset Intel i865P/PE/G/i848P rev. A2
Southbridge Intel 82801EB (ICH5) rev. A2
Sensor chip Winbond W83627HF
FSB Select 800 MHz
Performance Mode disabled
AGP Status enabled, rev. 3.0
AGP Data Transfert Rate 4x
AGP Side Band Addressing supported, not enabled
AGP Aperture Size 128 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 187.3 MHz
FSB
RAM 1:1
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 8 clocks
# of memory modules 2
Module 0 DDR-SDRAM PC3200 - 512 MBytes
Module 1 DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Workstation Service Pack 1 (Build 2600)
I would like to find out more about tweaking my os too.
also would like to upgrade vid card or tweaking software?
running a chaintec mx440 at 4spd agp
thanx to all of you
from Randy
