Hello guys! First time posting here! Glad to be part of it! =)
I've just bought a new note with an i5 8265u and I want to overclock it the right way.
Here are the specifications:
In the Intel site it says:
Base Frequency: 1,6GHz - Max Frequency: 3,9GHz
TDP: 15W - Max Configurable TDP: 25W
I have tried some options on the ThrottleStop 8.70 and I'm not sure if it is working. I've changed the SET MULTIPLIER to 2.2 and have whatched the temps to check the max it goes up. The results is around 90-93ºC. And playing some games it keeps around 80ºC. I don't know if I have to undervolt and how to config it the right way so if you guys can help me I'd be so grateful.
When I run Limit Reasons the THERMAL, EDP OTHER and PL1 goes RED sometimes. I don't know if it can be dangerous to my CPU.
I have tried to set it right to play DAYZ, and sometimes my pc get some good results, reaching 50-60 fps, but sometimes it goes really bad, downgrading to 19-30 fps. I don't understand why this difference is so high playing the same game.
What do you suggest me?
Really thank you!
Really thank you!
