- Dec 26, 2011
Hello, I am new to the overclocking community. I will start by sharing my rig with you guys.
Intel Core i7-920 Bloomfield 2.66GHz
GIGABYTE GA-EX58-UD3R-SLI LGA 1366 Intel X58 ATX Motherboard
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model
EVGA GeForce GTX 285 SC Edition 1GB 512-bit GDDR3
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
Windows Vista home premium 64bit
I have already overclocked my cpu to 3400.0MHz about a week ago.
Everything has been running fine and I ran a standard Intel Burn Test which finished well.
I also ran a Prime95 test for about 1.5 hrs with no problem.
However this morning I ran a Intel Burn Test on maximum and i blue screened. I also ran a Prime95 test and it gives me:
FATAL ERROR: Rounding was 1, expected less then 0.4
hardware failure detected, consult stress.txt file.
torture test ran 0 minutes - 1 errors, 0 warnings.
worker stopped.
When idle or surfing the web my cpu runs at 40-43C.
I have uploaded my CPU-Z info in a txt file
Here is a copy as well:
worker stopped.
Code:
CPU-Z version 1.50
Processors Map
Number of processors 1
Number of threads 8
Processor 0
-- Core 0
-- Thread 0
-- Thread 1
-- Core 1
-- Thread 0
-- Thread 1
-- Core 2
-- Thread 0
-- Thread 1
-- Core 3
-- Thread 0
-- Thread 1
Processors Information
Processor 1 (ID = 0)
Number of cores 4 (max 8)
Number of threads 8 (max 16)
Name Intel Core i7 920
Codename Bloomfield
Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
Package Socket 1366 LGA (platform ID = 1h)
CPUID 6.A.4
Extended CPUID 6.1A
Core Stepping C0/C1
Technology 45 nm
Core Speed 3400.0 MHz (20.0 x 170.0 MHz)
Rated Bus speed 3060.1 MHz
Stock frequency 2666 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 4-way set associative, 64-byte line size
L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 8 MBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
Features XD, VT
Turbo Mode not supported
Max non-turbo ratio 20x
Max efficiency ratio 12x
TDP Limit 130 Watts
TDC Limit 110 Amps
Core TDP 110 Watts
Uncore TDP 20 Watts
Power @ 12x 43 Watts
Power @ 13x 50 Watts
Power @ 14x 57 Watts
Power @ 15x 66 Watts
Power @ 16x 76 Watts
Power @ 17x 87 Watts
Power @ 18x 100 Watts
Power @ 19x 114 Watts
Power @ 20x 130 Watts
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01020001h
Max CPUID level 0000000Bh
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x0000000B 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000106A4 0x00100800 0x0098E3BD 0xBFEBFBFF
0x00000002 0x55035A01 0x00F0B2E4 0x00000000 0x09CA212C
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x1C004121 0x01C0003F 0x0000003F 0x00000000
0x00000004 0x1C004122 0x00C0003F 0x0000007F 0x00000000
0x00000004 0x1C004143 0x01C0003F 0x000001FF 0x00000000
0x00000004 0x1C03C163 0x03C0003F 0x00001FFF 0x00000002
0x00000005 0x00000040 0x00000040 0x00000003 0x00001120
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07300403 0x00000040 0x00000000 0x00000603
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000000
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x28100000
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x37692029 0x55504320 0x20202020 0x20202020
0x80000004 0x30323920 0x20402020 0x37362E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000100
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
Cache descriptor Level 1 D 32 KB 2 thread(s)
Cache descriptor Level 1 I 32 KB 2 thread(s)
Cache descriptor Level 2 U 256 KB 2 thread(s)
Cache descriptor Level 3 U 8 MB 16 thread(s)
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x000000E8 edx = 0x000000CF eax = 0xE322C77B
MSR 0x000000CE edx = 0x00000C00 eax = 0x00001400
MSR 0x00000017 edx = 0x00040000 eax = 0x00000000
MSR 0x00000035 edx = 0x00000000 eax = 0x00040008
MSR 0x000000C1 edx = 0x00000000 eax = 0x00000000
MSR 0x000000C2 edx = 0x00000000 eax = 0x00000000
MSR 0x000000C3 edx = 0x00000000 eax = 0x00000000
MSR 0x000000C4 edx = 0x00000000 eax = 0x00000000
MSR 0x00000186 edx = 0x00000000 eax = 0x00000000
MSR 0x00000187 edx = 0x00000000 eax = 0x00000000
MSR 0x0000019A edx = 0x00000000 eax = 0x00000000
MSR 0x000001A0 edx = 0x00000040 eax = 0x00840081
MSR 0x000001A4 edx = 0x00000000 eax = 0x00000000
MSR 0x000001AC edx = 0x00000000 eax = 0x03700410
MSR 0x000001FC edx = 0x00000000 eax = 0x00000000
MSR 0x00000300 edx = 0x00000000 eax = 0xE0000001
MSR 0x0000019C edx = 0x00000000 eax = 0x88350000
MSR 0x000001A2 edx = 0x00000000 eax = 0x00641400
MSR 0x00000198 edx = 0x00000000 eax = 0x00000014
MSR 0x00000199 edx = 0x00000000 eax = 0x00000014
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 0, Thread ID 1
Type 01020001h
0x00000001 0x000106A4 0x01100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000001
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000001
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
MSR 0x000000E8 edx = 0x0000005F eax = 0x91FF6A8F
MSR 0x0000019C edx = 0x00000000 eax = 0x88380000
CPU Thread 2
APIC ID 2
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01020001h
0x00000001 0x000106A4 0x02100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000002
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000002
MSR 0x000000E8 edx = 0x00000077 eax = 0xE0228F4C
MSR 0x0000019C edx = 0x00000000 eax = 0x883A0000
CPU Thread 3
APIC ID 3
Topology Processor ID 0, Core ID 1, Thread ID 1
Type 01020001h
0x00000001 0x000106A4 0x03100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000003
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000003
MSR 0x000000E8 edx = 0x0000005A eax = 0x1FCF1562
MSR 0x0000019C edx = 0x00000000 eax = 0x883B0000
CPU Thread 4
APIC ID 4
Topology Processor ID 0, Core ID 2, Thread ID 0
Type 01020001h
0x00000001 0x000106A4 0x04100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000004
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000004
MSR 0x000000E8 edx = 0x000000AE eax = 0x3DEBF1AB
MSR 0x0000019C edx = 0x00000000 eax = 0x88360000
CPU Thread 5
APIC ID 5
Topology Processor ID 0, Core ID 2, Thread ID 1
Type 01020001h
0x00000001 0x000106A4 0x05100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000005
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000005
MSR 0x000000E8 edx = 0x0000003C eax = 0x8E10AC56
MSR 0x0000019C edx = 0x00000000 eax = 0x88390000
CPU Thread 6
APIC ID 6
Topology Processor ID 0, Core ID 3, Thread ID 0
Type 01020001h
0x00000001 0x000106A4 0x06100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000006
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000006
MSR 0x000000E8 edx = 0x000000C2 eax = 0xCA3BC3DE
CPU Thread 7
APIC ID 7
Topology Processor ID 0, Core ID 3, Thread ID 1
Type 01020001h
0x00000001 0x000106A4 0x07100800 0x0098E3BD 0xBFEBFBFF
0x0000000B 0x00000001 0x00000002 0x00000100 0x00000007
0x0000000B 0x00000004 0x00000008 0x00000201 0x00000007
MSR 0x000000E8 edx = 0x0000004D eax = 0x867F68FA
MSR 0x0000019C edx = 0x00000000 eax = 0x883C0000
Chipset
Northbridge Intel X58 rev. 12
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 6144 MBytes
Channels Triple
Memory Frequency 680.0 MHz (2:8)
CAS# 10.0
RAS# to CAS# 9
RAS# Precharge 9
Cycle Time (tRAS) 22
Command Rate 1T
NB Frequency 2720.1 MHz
Memory SPD
DIMM #1
General
Memory type DDR3
Module format UDIMM
Manufacturer (ID) OCZ (7F7F7F7FB0000000)
Size 2048 MBytes
Max bandwidth PC3-8500F (533 MHz)
Part number OCZ3G1600LV2G
Attributes
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP no
Timings table
Frequency (MHz) 381 457 533 610
CAS# 5.0 6.0 7.0 8.0
RAS# to CAS# delay 6 6 7 9
RAS# Precharge 6 6 7 9
TRAS 12 14 16 19
TRC 19 23 27 31
DIMM #2
General
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Attributes
Number of banks 8
EPP no
XMP no
Timings table
TRAS 12 14 16 19
TRC 19 23 27 31
DIMM #3
General
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Attributes
Number of banks 8
EPP no
XMP no
Timings table
TRAS 12 14 16 19
TRC 19 23 27 31
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 93 10 0B 02 02 11 00 09 03 52 01 08 0F 00 1E 00
10 69 78 69 3C 69 10 F0 8C 70 03 3C 3C 00 F0 03 04
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 84 B0 02 00 00 00 00 00 00 3F 58
80 4F 43 5A 33 47 31 36 30 30 4C 56 32 47 20 20 20
90 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dump Module #2
Dump Module #3
Monitoring
Mainboard Model UD3R-SLI (0x233 - 0xBD89EA)
LPCIO
Vendor ITE
Model IT8720
Vendor ID 0x90
Chip ID 0x8720
Revision ID 0x5
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0x4
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 20 05 00 00 40 28 1E 00 80 00 00 81 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Hardware monitor
ITE IT87 hardware monitor
Voltage sensor 0 1.30 Volts [0x51] (CPU VCORE)
Voltage sensor 1 1.62 Volts [0x65] (VIN1)
Voltage sensor 2 3.34 Volts [0xD1] (+3.3V)
Voltage sensor 3 5.05 Volts [0xBC] (+5V)
Voltage sensor 4 2.43 Volts [0x26] (+12V)
Voltage sensor 5 -12.29 Volts [0xC0] (-12V)
Voltage sensor 6 -0.77 Volts [0xC] (-5V)
Voltage sensor 7 3.63 Volts [0x87] (+5V VCCH)
Voltage sensor 8 3.26 Volts [0xCC] (VBAT)
Temperature sensor 0 37°C (98°F) [0x25] (TMPIN0)
Temperature sensor 1 39°C (102°F) [0x27] (TMPIN1)
Temperature sensor 2 47°C (116°F) [0x2F] (TMPIN2)
Fan sensor 0 1227 RPM [0x226] (FANIN0)
Dump hardware monitor
LPC Register space, base address = 0x0290
00 13 10 00 00 FF FF 00 37 FF 87 58 0F 17 28 FF FF
10 FF FF FF 76 D7 81 80 81 02 FF FF FF FF FF FF FF
20 50 65 D1 BC 48 C0 1A 87 CC 25 27 2F 80 2C D1 D1
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 74 2D 40 95 00 FF FF FF FF
50 FF 2A 7F 7F 7F 50 0B 0B 90 0B 02 12 60 00 00 00
60 00 14 41 23 90 03 00 FF 00 14 41 23 90 03 00 FF
70 00 14 41 23 90 03 00 FF FF FF FF FF FF FF FF FF
80 FF FF 00 00 FF FF 00 00 00 00 00 00 00 00 02 00
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Intel Core i7 920 hardware monitor
Temperature sensor 0 47°C (116°F) [0x35] (Core #0)
Temperature sensor 1 42°C (107°F) [0x3A] (Core #1)
Temperature sensor 2 46°C (114°F) [0x36] (Core #2)
Temperature sensor 3 43°C (109°F) [0x39] (Core #3)
Hardware monitor
GeForce GTX 285 hardware monitor
Temperature sensor 0 48°C (118°F) [0x30] (GPU Core)
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3405
Revision ID 0x12
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x0C
Int. Pin 0x01
Capabilities
Message Signalled Interrupts Capability
Offset 60h
PCI Express Capability
Offset 90h
Device type Root Port of PCI-E Root Complex
Port 0
Version 2.0
Physical slot Integrated device
Link width 4x (max 4x)
Power Management Capability
Offset E0h
Version 1.2
Extended capabilities
Advanced Error Reporting Capability
Offset 100h
PCI Capability class 0xD
Offset 150h
Vendor Specific
Offset 160h
Vendor ID 2
Size 12
Dump
00 86 80 05 34 00 00 10 00 12 00 00 06 10 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 00 50
30 00 00 00 00 60 00 00 00 00 00 00 00 0C 01 00 00
50 01 40 D1 FE 00 00 00 00 00 00 00 00 00 00 00 00
60 05 90 02 01 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 10 E0 42 00 20 80 00 00 00 00 00 00 41 3C 39 00
A0 00 00 41 30 00 00 00 00 C0 07 00 01 00 00 00 00
B0 00 00 00 00 3E 00 00 00 00 00 00 00 00 00 00 00
C0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 01 00 03 C8 08 00 00 00 00 00 00 00 00 00 00 00
100 01 00 01 15 00 00 00 00 00 40 00 00 30 20 06 00
110 00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3408
Revision ID 0x12
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x10
Int. Pin 0x01
Capabilities
Subsystem Vendor Capability
Offset 40h
Subsystem ID 0x5001
Sub. Vendor ID 0x1458
Offset 60h
Offset 90h
Port 0
Version 2.0
Link width 0x (max 4x)
Offset E0h
Version 1.2
Offset 100h
Offset 150h
Vendor Specific
Offset 160h
Vendor ID 2
Size 12
Dump
00 86 80 08 34 07 00 10 00 12 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 70 70 00 00
20 B0 FD B0 FD A1 FD A1 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 10 01 00 00
40 0D 60 00 00 58 14 01 50 00 00 00 00 00 00 00 00
90 10 E0 42 00 21 80 00 00 20 00 00 00 42 3C 39 00
A0 00 00 01 10 00 00 00 00 C0 03 40 00 00 00 01 00
B0 00 00 00 00 3E 00 00 00 09 00 00 00 00 00 00 00
100 01 00 01 15 00 00 00 00 00 00 00 00 30 20 06 00
PCI to PCI Bridge
bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x340A
Revision ID 0x12
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Subsystem ID 0x5001
Offset 60h
Offset 90h
Port 0
Version 2.0
Link width 0x (max 16x)
Offset E0h
Version 1.2
Offset 100h
Offset 150h
Vendor Specific
Offset 160h
Vendor ID 2
Size 12
Dump
00 86 80 0A 34 07 00 10 00 12 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 02 02 00 E0 E0 00 00
20 90 FD 90 FD 21 FD 21 FD 00 00 00 00 00 00 00 00
90 10 E0 42 00 21 80 00 00 20 00 00 00 02 3D 39 00
PCI to PCI Bridge
bus 0 (0x00), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x340C
Revision ID 0x12
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x03
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Subsystem ID 0x5001
Offset 60h
Offset 90h
Port 0
Version 2.0
Link width 0x (max 0x)
Offset E0h
Version 1.2
Offset 100h
Offset 150h
Dump
00 86 80 0C 34 07 00 10 00 12 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 03 03 00 D0 D0 00 00
20 F0 FC F0 FC E1 FD E1 FD 00 00 00 00 00 00 00 00
90 10 E0 42 00 21 80 00 00 20 00 00 00 02 3C 39 00
PCI to PCI Bridge
bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x340E
Revision ID 0x12
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x04
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Subsystem ID 0x5001
Offset 60h
Offset 90h
Port 0
Version 2.0
Link width 16x (max 16x)
Offset E0h
Version 1.2
Offset 100h
Offset 150h
Vendor Specific
Offset 160h
Vendor ID 2
Size 12
Dump
00 86 80 0E 34 07 00 10 00 12 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 04 04 00 90 90 00 00
20 00 F8 F0 FB 01 D0 F1 DF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 10 01 18 00
90 10 E0 42 00 21 80 00 00 00 00 00 00 02 3D 39 00
A0 00 00 02 71 00 00 00 00 C0 03 40 00 00 00 01 00
C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3410
Revision ID 0x12
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x05
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Subsystem ID 0x5001
Offset 60h
Offset 90h
Port 0
Version 2.0
Offset E0h
Version 1.2
Offset 100h
Offset 150h
Dump
00 86 80 10 34 07 00 10 00 12 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 05 05 00 80 80 00 00
20 D0 FD D0 FD C1 FD C1 FD 00 00 00 00 00 00 00 00
A0 00 00 02 10 00 00 00 00 C0 03 40 00 00 00 01 00
System Device
bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3425
Revision ID 0x12
PI 0x00
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Vendor Dependant Capability
Offset 50h
Dump
00 86 80 25 34 00 00 10 00 12 00 00 08 10 00 80 00
30 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00 00
50 09 00 FF F0 02 00 C0 00 00 68 00 00 39 00 00 00
60 88 C6 FA 07 00 00 00 00 00 00 00 00 00 00 00 00
80 07 02 00 02 00 20 7F 00 00 10 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 08 96 08 00 00 00 00 00 FC 06 06 00 00 5F 00
D0 C5 00 00 00 00 00 D1 00 00 00 00 00 81 04 01 00
F0 00 00 00 00 00 00 00 00 64 11 11 11 64 11 11 11
System Device
bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3426
Revision ID 0x12
PI 0x00
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 26 34 00 00 00 00 12 00 00 08 10 00 80 00
40 01 00 00 00 00 00 00 00 00 00 00 00 46 22 40 00
50 08 00 02 00 00 00 00 00 02 00 00 00 00 00 00 00
60 00 00 00 00 40 00 00 00 00 00 00 00 02 00 00 00
80 01 00 41 10 04 41 10 04 00 00 00 00 00 00 00 00
B0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
D0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
System Device
bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3427
Revision ID 0x12
PI 0x00
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
PCI Capability class 0x0
Offset 50h
Dump
00 86 80 27 34 00 00 10 00 12 00 00 08 10 00 80 00
System Device
bus 0 (0x00), device 17 (0x11), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3428
Revision ID 0x12
PI 0x00
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 28 34 00 00 00 00 12 00 00 08 10 00 80 00
A0 40 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00
B0 80 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00
C0 40 00 FF 00 FF FF FF FF 00 00 00 00 00 00 00 00
D0 A0 00 00 00 FF FF FF FF 00 00 00 00 00 00 00 00
E0 01 00 00 00 16 18 00 00 00 00 00 00 00 00 00 00
System Device
bus 0 (0x00), device 19 (0x13), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x342D
Revision ID 0x12
PI 0x20
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xFDFFF000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 6Ch
Version 1.2
Dump
00 86 80 2D 34 06 00 10 00 12 20 00 08 10 00 80 00
10 00 F0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 6C 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 01 00 03 C8
A0 A8 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00
System Device
bus 0 (0x00), device 20 (0x14), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x342E
Revision ID 0x12
PI 0x00
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 40h
Device type Root Complex Integrated Endpoint Device
Port 0
Version 2.0
Dump
00 86 80 2E 34 00 00 10 00 12 00 00 08 10 00 80 00
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
40 10 00 92 00 00 80 00 00 00 00 00 00 00 F4 3B 00
50 00 00 00 10 00 00 00 00 C0 07 00 00 00 00 01 00
60 00 00 00 00 00 80 00 00 00 00 00 00 00 F4 3B 00
70 00 00 00 10 00 00 00 00 C0 07 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 FF FF FF FF 07 00
90 00 00 00 00 00 00 00 00 48 00 04 00 14 EC 03 00
A0 00 00 00 00 00 00 00 00 03 00 F0 CF 00 00 00 00
B0 00 00 FF FF FF FF 07 00 00 00 00 00 00 00 00 00
C0 00 00 FF FF FF FF 07 00 00 00 00 00 00 00 00 00
D0 00 00 00 CC 00 00 00 AC 01 00 00 00 00 00 00 FC
E0 FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
F0 54 F5 FF 03 00 00 00 00 80 7F 00 00 00 00 00 00
100 00 00 00 00 00 00 00 00 00 F0 00 01 00 D0 00 FE
110 00 FC 00 00 00 00 00 00 00 00 00 00 00 FD 00 00
120 00 F0 00 00 00 D0 00 FE 00 FC 00 00 00 00 00 00
130 00 00 00 00 00 FD 00 00 00 00 00 00 00 00 00 00
System Device
bus 0 (0x00), device 20 (0x14), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3422
Revision ID 0x12
PI 0x00
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 40h
Port 0
Version 2.0
Dump
00 86 80 22 34 00 00 10 00 12 00 00 08 10 00 80 00
80 00 00 00 00 01 0C 14 14 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 21 54 05 02 00 00 00 BF
A0 00 00 00 00 00 08 90 00 05 00 90 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 D0 FE FF 00 00 00 00
E0 00 00 00 00 01 0C 14 14 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 21 54 05 02 00 00 00 BF
100 00 00 00 00 00 00 00 00 00 08 90 00 05 00 90 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 D0 FE FF
System Device
bus 0 (0x00), device 20 (0x14), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3423
Revision ID 0x12
PI 0x00
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 40h
Port 0
Version 2.0
Dump
00 86 80 23 34 00 00 10 00 12 00 00 08 10 00 80 00
80 A4 82 A0 02 50 01 AA AA A8 00 00 00 65 15 00 00
90 00 00 00 00 24 00 00 00 04 08 00 00 22 05 00 00
C0 01 00 00 00 00 00 00 00 00 00 00 00 00 42 00 00
D0 00 00 00 00 00 08 08 92 95 00 BD 35 00 00 10 00
E0 40 58 04 00 FB 03 00 00 FF 07 00 00 00 00 00 00
100 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
System Device
bus 0 (0x00), device 21 (0x15), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x342F
Revision ID 0x12
PI 0x20
SubClass 0x00
BaseClass 0x08
Cache Line 0x10
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 2F 34 00 00 00 00 12 20 00 08 10 00 80 00
USB Controller (UHCI)
bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A37
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000FF00
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x10
Int. Pin 0x01
Capabilities
PCI Capability class 0x13
Offset 50h
Dump
00 86 80 37 3A 05 00 90 02 00 00 03 0C 00 00 80 00
20 01 FF 00 00 00 00 00 00 00 00 00 00 58 14 04 50
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
50 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 2F 00 00 00 00 00 00 00 00 01 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 86 0F 00 00 00 00 00 00
bus 0 (0x00), device 26 (0x1A), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3A38
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FE00
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 50h
Dump
00 86 80 38 3A 05 00 90 02 00 00 03 0C 00 00 00 00
20 01 FE 00 00 00 00 00 00 00 00 00 00 58 14 04 50
30 00 00 00 00 50 00 00 00 00 00 00 00 15 02 00 00
bus 0 (0x00), device 26 (0x1A), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3A39
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FD00
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x12
Int. Pin 0x03
Capabilities
Offset 50h
Dump
00 86 80 39 3A 05 00 90 02 00 00 03 0C 00 00 00 00
20 01 FD 00 00 00 00 00 00 00 00 00 00 58 14 04 50
30 00 00 00 00 50 00 00 00 00 00 00 00 12 03 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 26 (0x1A), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x3A3C
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDFFE000
Subvendor ID 0x1458
Subsystem ID 0x5006
Int. Line 0x12
Int. Pin 0x03
Capabilities
Offset 50h
Version 1.1
Debug Port Capability
Offset 58h
Offset 98h
Dump
00 86 80 3C 3A 06 00 90 02 00 20 03 0C 00 00 00 00
10 00 E0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 06 50
50 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00
60 20 20 FF 01 00 00 00 00 01 00 00 01 00 20 00 C0
70 00 00 D7 0F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00
D0 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 86 85 40 80 86 0F 00 00 0A 13 02 20
Multimedia device
bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A3E
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDFF8000
Subvendor ID 0x1458
Subsystem ID 0xA002
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Offset 60h
Offset 70h
Port 0
Version 1.0
Virtual Channel
Offset 100h
Root Complex Link Declaration
Offset 130h
Link Entries # 1
Port Number 15
Dump
00 86 80 3E 3A 06 00 10 00 00 00 03 04 10 00 00 00
10 04 80 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 02 A0
30 00 00 00 00 50 00 00 00 00 00 00 00 16 01 00 00
40 01 00 00 07 07 00 00 00 00 00 00 00 00 00 00 00
50 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
60 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 00 91 00 00 00 00 10 00 08 10 00 00 00 00 00
C0 00 04 00 01 00 00 00 00 31 00 A3 02 00 00 00 00
D0 61 00 A3 02 00 00 00 00 00 00 00 00 00 00 00 00
100 02 00 01 13 01 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
120 80 00 00 81 00 00 00 00 00 00 00 00 00 00 00 00
130 05 00 01 00 00 01 02 0F 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A40
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x06
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Port 1
Version 1.0
Physical slot #2
Presence detect no
Link width 0x (max 1x)
Offset 80h
Offset 90h
Subsystem ID 0x5001
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 1
Dump
00 86 80 40 3A 07 00 10 00 00 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 06 06 00 C0 C0 00 20
20 80 FD 80 FD 71 FD 71 FD 00 00 00 00 00 00 00 00
40 10 80 41 01 00 80 00 00 00 00 10 00 11 44 11 01
50 00 00 01 10 60 05 80 00 00 00 00 00 00 00 00 00
80 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 0D A0 00 00 58 14 01 50 00 00 00 00 00 00 00 00
A0 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 11 08 00 00 00 00
E0 00 00 C7 00 06 07 08 00 30 00 00 00 00 00 00 00
100 02 00 01 18 00 00 00 00 01 00 00 00 00 00 00 00
110 01 00 00 00 01 00 00 80 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3A42
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x07
Int. Line 0x11
Int. Pin 0x02
Capabilities
Offset 40h
Port 2
Version 1.0
Physical slot #2
Presence detect yes
Link width 1x (max 1x)
Offset 80h
Offset 90h
Subsystem ID 0x5001
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 2
Dump
00 86 80 42 3A 07 00 10 00 00 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 07 07 00 B0 B0 00 00
20 60 FD 60 FD 51 FD 51 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 11 02 00 00
40 10 80 41 01 00 80 00 00 00 00 10 00 11 24 11 02
50 40 00 11 30 60 05 88 00 00 00 48 01 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 28 (0x1C), function 4 (0x04)
Common header
Vendor ID 0x8086
Model ID 0x3A48
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x08
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 40h
Port 5
Version 1.0
Physical slot #2
Presence detect yes
Offset 80h
Offset 90h
Subsystem ID 0x5001
Offset A0h
Version 1.1
Virtual Channel
Offset 100h
Offset 180h
Link Entries # 1
Port Number 5
Dump
00 86 80 48 3A 07 00 10 00 00 00 04 06 10 00 81 00
10 00 00 00 00 00 00 00 00 00 08 08 00 A0 A0 00 00
20 40 FD 40 FD 31 FD 31 FD 00 00 00 00 00 00 00 00
40 10 80 41 01 00 80 00 00 00 00 11 00 11 24 11 05
50 40 00 11 30 60 05 A0 00 00 00 48 01 00 00 00 00
bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A34
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000FC00
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 50h
Dump
00 86 80 34 3A 05 00 90 02 00 00 03 0C 00 00 80 00
20 01 FC 00 00 00 00 00 00 00 00 00 00 58 14 04 50
30 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x3A35
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FB00
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x13
Int. Pin 0x02
Capabilities
Offset 50h
Dump
00 86 80 35 3A 05 00 90 02 00 00 03 0C 00 00 00 00
20 01 FB 00 00 00 00 00 00 00 00 00 00 58 14 04 50
30 00 00 00 00 50 00 00 00 00 00 00 00 13 02 00 00
bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3A36
Revision ID 0x00
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FA00
Subvendor ID 0x1458
Subsystem ID 0x5004
Int. Line 0x12
Int. Pin 0x03
Capabilities
Offset 50h
Dump
00 86 80 36 3A 05 00 90 02 00 00 03 0C 00 00 00 00
20 01 FA 00 00 00 00 00 00 00 00 00 00 58 14 04 50
bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x3A3A
Revision ID 0x00
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDFFD000
Subvendor ID 0x1458
Subsystem ID 0x5006
Int. Line 0x17
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Offset 58h
Offset 98h
Dump
00 86 80 3A 3A 06 00 90 02 00 20 03 0C 00 00 00 00
10 00 D0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0x90
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x09
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 50h
Subsystem ID 0x5000
Dump
00 86 80 4E 24 07 00 10 00 90 01 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 09 09 20 60 60 80 22
20 10 FD 10 FD 01 FD 01 FD 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 12 00 00
50 0D 00 00 00 58 14 00 50 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x3A16
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5001
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset E0h
Dump
00 86 80 16 3A 07 01 10 02 00 00 01 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 01 50
30 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
40 01 04 00 00 80 00 00 00 81 04 00 00 10 00 00 00
60 8C 8A 87 8B D0 00 00 00 80 89 85 83 F8 00 00 00
80 00 00 08 34 01 08 0C 00 91 02 0C 00 00 00 00 00
A0 E0 06 00 00 38 02 00 00 13 1C 0A 24 00 03 00 40
B0 00 00 F0 00 00 00 00 00 55 55 55 59 00 00 00 00
D0 33 22 11 00 67 45 00 00 80 C0 00 00 08 00 00 00
E0 09 00 0C 10 01 00 C4 02 64 02 00 00 00 00 00 00
F0 01 C0 D1 FE 00 00 00 00 86 0F 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x3A20
Revision ID 0x00
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000F900
Address 5 (port) 0x0000F800
Subvendor ID 0x1458
Subsystem ID 0xB002
Int. Line 0xFF
Int. Pin 0x02
Capabilities
Offset 70h
Version 1.2
Offset B0h
Dump
00 86 80 20 3A 05 00 B0 02 00 8A 01 01 00 00 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 01 F9 00 00 01 F8 00 00 00 00 00 00 58 14 02 B0
30 00 00 00 00 70 00 00 00 00 00 00 00 FF 02 00 00
40 07 A3 07 A3 00 00 00 00 05 00 01 01 00 00 00 00
50 00 00 00 00 00 50 00 00 00 00 00 00 00 00 00 00
70 01 B0 03 00 08 00 00 00 00 00 00 00 00 00 00 00
80 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 0F 83 93 01 80 00 00 00 00 00 00 00 00 00
B0 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x3A30
Revision ID 0x00
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFDFFC000
Address 4 (port) 0x00000500
Subvendor ID 0x1458
Subsystem ID 0x5001
Int. Line 0x07
Int. Pin 0x03
Dump
00 86 80 30 3A 03 00 80 02 00 00 05 0C 00 00 00 00
10 04 C0 FF FD 00 00 00 00 00 00 00 00 00 00 00 00
20 01 05 00 00 00 00 00 00 00 00 00 00 58 14 01 50
30 00 00 00 00 00 00 00 00 00 00 00 00 07 03 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00
80 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
Vendor ID 0x8086
Model ID 0x3A26
Revision ID 0x00
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000F600
Address 1 (port) 0x0000F500
Address 2 (port) 0x0000F400
Address 3 (port) 0x0000F300
Address 4 (port) 0x0000F200
Address 5 (port) 0x0000F100
Subvendor ID 0x1458
Subsystem ID 0xB002
Int. Line 0x13
Int. Pin 0x02
Capabilities
Offset 70h
Version 1.2
Offset B0h
Dump
00 86 80 26 3A 05 00 B0 02 00 85 01 01 00 00 00 00
10 01 F6 00 00 01 F5 00 00 01 F4 00 00 01 F3 00 00
20 01 F2 00 00 01 F1 00 00 00 00 00 00 58 14 02 B0
30 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
40 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00
VGA Controller
bus 4 (0x04), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x05E3
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFA000000
Address 1 (memory) 0xD0000000
Address 3 (memory) 0xF8000000
Address 5 (port) 0x00009F00
Subvendor ID 0x3842
Subsystem ID 0x1285
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.2
Offset 68h
Offset 78h
Device type PCI-E Endpoint Device
Port 0
Version 2.0
Virtual Channel
Offset 100h
Power Budgeting Capability
Offset 128h
Vendor Specific
Offset 600h
Vendor ID 1
Size 36
Dump
00 DE 10 E3 05 07 00 10 00 A1 00 00 03 10 00 00 00
10 00 00 00 FA 0C 00 00 D0 00 00 00 00 04 00 00 F8
20 00 00 00 00 01 9F 00 00 00 00 00 00 42 38 85 12
30 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
40 42 38 85 12 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 03 00 08 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 02 00 E0 84 00 00
80 10 29 00 00 02 2D 00 00 08 00 02 01 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00
A0 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
100 02 00 81 12 00 00 00 00 00 00 00 00 00 00 00 00
110 00 00 00 00 FF 00 00 80 00 00 00 00 00 00 00 00
120 00 00 00 00 00 00 00 00 04 00 01 60 00 00 00 00
130 21 81 07 00 00 00 00 00 00 00 00 30 00 00 FF 33
IDE Controller
bus 7 (0x07), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x197B
Model ID 0x2363
Revision ID 0x02
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000BF00
Address 1 (port) 0x0000BE00
Address 2 (port) 0x0000BD00
Address 3 (port) 0x0000BC00
Address 4 (port) 0x0000BB00
Address 5 (memory) 0xFD6FE000
Subvendor ID 0x1458
Subsystem ID 0xB000
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 68h
Version 1.1
Offset 50h
Device type Legacy PCI-E Endpoint Device
Port 1
Version 1.0
Dump
00 7B 19 63 23 07 00 10 00 02 85 01 01 10 00 00 00
10 01 BF 00 00 01 BE 00 00 01 BD 00 00 01 BC 00 00
20 01 BB 00 00 00 E0 6F FD 00 00 00 00 58 14 00 B0
30 00 00 00 00 68 00 00 00 00 00 00 00 11 01 00 00
40 B1 A1 C0 00 08 08 FF E0 20 00 00 24 00 00 00 00
50 10 00 11 02 00 00 00 00 00 20 00 00 11 F4 03 01
60 00 00 11 10 00 00 00 00 01 50 02 40 00 00 00 00
80 08 08 A0 00 A0 01 0A 00 0F AA 0F 00 00 00 00 00
C0 C3 8B 38 00 03 45 02 00 9C 34 27 C0 49 92 00 00
D0 18 00 80 80 01 00 00 00 01 10 EB 00 00 00 00 01
E0 00 00 00 00 00 00 00 00 9C 34 27 C0 49 92 00 89
Ethernet Controller
bus 8 (0x08), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10EC
Model ID 0x8168
Revision ID 0x03
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000AE00
Address 2 (memory) 0xFD3FF000
Address 4 (memory) 0xFD3F8000
Subvendor ID 0x1458
Subsystem ID 0xE000
Int. Line 0x00
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.2
Offset 50h
Offset 70h
Port 0
Version 2.0
MSI-X Capability
Offset ACh
Virtual Product Data Capability
Offset CCh
Offset 100h
Virtual Channel
Offset 140h
Device Serial Number
Offset 160h
Dump
00 EC 10 68 81 07 04 10 00 03 00 00 02 10 00 00 00
10 01 AE 00 00 00 00 00 00 0C F0 3F FD 00 00 00 00
20 0C 80 3F FD 00 00 00 00 00 00 00 00 58 14 00 E0
30 00 00 00 00 40 00 00 00 00 00 00 00 00 01 00 00
40 01 50 C3 FF 08 00 00 00 00 00 00 00 00 00 00 00
50 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
70 10 AC 02 02 C1 8C 28 00 10 50 10 00 11 3C 07 00
80 00 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 11 CC 03 80
B0 04 00 00 00 04 08 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 03 00 00 00
100 01 00 01 14 00 00 00 00 00 00 00 00 30 20 06 00
110 01 00 00 00 00 20 00 00 A0 00 00 00 00 00 00 00
OHCI FireWire Controller
bus 9 (0x09), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x104C
Model ID 0x8024
Revision ID 0x00
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x10
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFD1FF000
Address 1 (memory) 0xFD1F8000
Subvendor ID 0x1458
Subsystem ID 0x1000
Int. Line 0x12
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 4C 10 24 80 06 00 10 02 00 10 00 0C 10 20 00 00
10 00 F0 1F FD 00 80 1F FD 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 58 14 00 10
30 00 00 00 00 44 00 00 00 00 00 00 00 12 01 02 04
40 00 00 00 00 01 00 02 7E 00 80 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00
F0 10 00 00 00 86 10 00 00 58 14 00 10 00 00 00 00
Host Bridge
bus 255 (0xFF), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2C41
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 41 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 20 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00
60 20 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00
C0 10 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2C01
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 01 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 10 11 11 00 00 00 00 00 00 00 00 00 00 0A 00 00
50 01 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 E8 5D 00 00 00 00 00 00 00 00 00 00 00 00
80 C3 0C 00 00 C0 0F 00 00 C3 1A 00 00 C0 1A 00 00
90 C0 1A 00 00 C0 1A 00 00 C0 1A 00 00 C0 1A 00 00
C0 11 11 11 11 00 00 00 00 11 11 11 11 00 00 00 00
Host Bridge
bus 255 (0xFF), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2C10
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 10 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 00 01 8F 08 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 86 00 00 00 00 55 45 06 00 00 00 00 00
80 AA EB 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 7F 00 86 02 00 00 00 00 00 B3 00 00 00 00
D0 01 07 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2C11
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 11 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 09 00 FF F0 01 00 80 0B 00 00 10 00 73 02 00 00
50 12 01 0C 7E 12 00 00 00 01 00 00 00 01 00 00 00
60 00 00 00 00 00 00 00 00 00 51 C3 10 A0 A0 40 00
70 00 00 00 00 FF FF 0F 80 00 00 00 00 FF FF 0F 00
80 03 0F 0F 07 00 00 00 00 01 00 00 00 01 00 0F 0F
90 82 00 00 00 02 02 01 00 08 08 88 08 02 05 00 00
A0 00 54 01 00 08 28 32 00 84 00 00 06 02 00 00 00
B0 77 15 AE 4D 00 00 00 00 00 00 00 00 01 00 00 00
D0 00 00 11 04 00 00 00 00 00 00 00 00 03 00 08 00
E0 00 00 02 00 00 00 40 00 00 00 82 24 00 00 00 00
F0 00 00 00 00 42 01 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2C18
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 18 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 00 00 00 00 00 00 00 00 40 07 00 00 08 00 00 00
50 00 00 00 00 FF 00 00 00 00 00 00 00 00 00 00 00
60 89 44 02 00 94 00 00 00 00 00 00 00 00 00 00 00
70 0E 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00
Host Bridge
bus 255 (0xFF), device 3 (0x03), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2C19
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 19 2C 06 00 00 00 04 00 00 06 00 00 80 00
80 85 0C 00 00 C3 0C 00 00 C0 0F 00 00 45 1A 00 00
90 C3 1A 00 00 C0 1A 00 00 C0 1A 00 00 C0 1A 00 00
C0 10 02 10 02 22 22 22 22 00 00 00 00 10 02 10 02
D0 01 01 01 01 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 3 (0x03), function 4 (0x04)
Common header
Vendor ID 0x8086
Model ID 0x2C1C
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 1C 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 09 00 FF F0 01 00 80 0B 03 10 10 04 E7 00 01 03
50 08 00 00 1E 08 00 00 00 15 00 00 00 01 00 00 00
60 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 0E 00 00 00 00 00 00 00
B0 EF CD AB 89 00 00 00 00 00 00 00 00 01 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00
D0 0F 00 11 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 09 0A 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 4 (0x04), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2C20
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 20 2C 06 00 00 00 04 00 00 06 00 00 80 00
50 00 00 00 00 00 00 00 00 31 7C 3F 06 40 01 00 00
60 F0 18 90 00 00 00 00 00 01 00 00 00 0C 00 00 00
70 68 19 42 08 58 04 00 00 00 00 00 00 03 00 00 00
80 58 44 3C 12 54 B5 00 00 69 F3 2C 00 4A FA 54 02
90 9B 02 90 32 90 1A 40 60 F0 3D 01 00 50 62 A5 03
A0 00 00 00 00 00 00 01 01 04 04 01 01 01 02 05 09
B0 05 06 05 09 FF FF AF 0D C0 11 00 00 40 10 00 00
C0 10 04 08 00 04 01 02 00 10 08 07 00 00 08 00 00
D0 0F 0F 00 00 3E 00 00 00 03 20 00 00 00 00 00 00
E0 10 04 00 00 00 01 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 4 (0x04), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2C21
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 21 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 00 00 00 00 00 00 00 00 A8 02 00 00 00 10 00 00
50 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 08 00 00 00 00 00 00 00 00 00 CC FF 08
90 00 50 FF 01 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 4 (0x04), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2C22
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 22 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00
50 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00 00
80 00 00 00 00 01 00 00 00 00 00 00 00 01 00 00 00
Host Bridge
bus 255 (0xFF), device 4 (0x04), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x2C23
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 23 2C 06 00 00 00 04 00 00 06 00 00 80 00
40 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00
60 00 00 00 00 00 01 FF 04 00 00 00 00 00 00 00 00
80 FF FF FF FF 00 40 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 07 00 00 00 01 00 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 5 (0x05), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2C28
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 28 2C 06 00 00 00 04 00 00 06 00 00 80 00
D0 0F 0F 00 00 40 00 00 00 03 20 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 5 (0x05), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2C29
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 29 2C 06 00 00 00 04 00 00 06 00 00 80 00
Host Bridge
bus 255 (0xFF), device 5 (0x05), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2C2A
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 2A 2C 06 00 00 00 04 00 00 06 00 00 80 00
Host Bridge
bus 255 (0xFF), device 5 (0x05), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x2C2B
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 2B 2C 06 00 00 00 04 00 00 06 00 00 80 00
Host Bridge
bus 255 (0xFF), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2C30
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 30 2C 06 00 00 00 04 00 00 06 00 00 80 00
D0 0F 0F 00 00 3F 00 00 00 03 20 00 00 00 00 00 00
Host Bridge
bus 255 (0xFF), device 6 (0x06), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x2C31
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 31 2C 06 00 00 00 04 00 00 06 00 00 80 00
80 00 00 00 08 00 78 FF 00 00 00 00 00 00 D8 FF 08
Host Bridge
bus 255 (0xFF), device 6 (0x06), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x2C32
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 32 2C 06 00 00 00 04 00 00 06 00 00 80 00
Host Bridge
bus 255 (0xFF), device 6 (0x06), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x2C33
Revision ID 0x04
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1458
Subsystem ID 0x5000
Int. Line 0x00
Int. Pin 0x00
Dump
00 86 80 33 2C 06 00 00 00 04 00 00 06 00 00 80 00
DMI
DMI BIOS
vendor Award Software International, Inc.
version F1
date 01/23/2009
DMI System Information
manufacturer Gigabyte Technology Co., Ltd.
product UD3R-SLI
version unknown
serial unknown
UUID 00000000-00000000-00000024-1D12E6C2
DMI Baseboard
vendor Gigabyte Technology Co., Ltd.
model UD3R-SLI
revision x.x
serial unknown
DMI System Enclosure
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Core(TM) i7 CPU
clock speed 3400.0 MHz
FSB speed 170.0 MHz
multiplier 20.0x
DMI Memory Controller
correction 8-bit parity
Max module size 1024 MBytes
DMI Memory Module
designation A0
size 2048 MBytes (single bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
designation No Detected (external)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB (internal)
port type USB
connector Access Bus (USB)
DMI Port Connector
port type USB
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type unknown
total width 2304 bits
data width 2274 bits
size 2048 MBytes
DMI Memory Device
designation A1
format DIMM
type unknown
DMI Memory Device
designation A2
format DIMM
type unknown
size 2048 MBytes
DMI Memory Device
designation A3
format DIMM
type unknown
Display I2C
Software
Windows Version Microsoft Windows Vista (6.0) Home Premium Edition Service Pack 2 (Build 6002)
DirectX Version 10.0
Resources
Memory I/O Space, BA=0x00000000FDFFF000
Port I/O Space, BA=0xFF00
Port I/O Space, BA=0xFE00
Port I/O Space, BA=0xFD00
Memory I/O Space, BA=0x00000000FDFFE000
Memory I/O Space, BA=0x00000000FDFF8000
Port I/O Space, BA=0xFC00
Port I/O Space, BA=0xFB00
Port I/O Space, BA=0xFA00
Memory I/O Space, BA=0x00000000FDFFD000
Port I/O Space, BA=0xF900
Port I/O Space, BA=0xF800
Memory I/O Space, BA=0x00000000FDFFC000
Port I/O Space, BA=0x500
Port I/O Space, BA=0xF600
Port I/O Space, BA=0xF500
Port I/O Space, BA=0xF400
Port I/O Space, BA=0xF300
Port I/O Space, BA=0xF200
Port I/O Space, BA=0xF100
Memory I/O Space, BA=0x00000000FA000000
Memory I/O Space, BA=0x00000000D0000000
Memory I/O Space, BA=0x00000000F8000000
Port I/O Space, BA=0x9F00
Port I/O Space, BA=0xBF00
Port I/O Space, BA=0xBE00
Port I/O Space, BA=0xBD00
Port I/O Space, BA=0xBC00
Port I/O Space, BA=0xBB00
Memory I/O Space, BA=0x00000000FD6FE000
Port I/O Space, BA=0xAE00
Memory I/O Space, BA=0x00000000FD3FF000
Memory I/O Space, BA=0x00000000FD3F8000
Memory I/O Space, BA=0x00000000FD1FF000
Memory I/O Space, BA=0x00000000FD1F8000
Port I/O Space, BA=0x408, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Memory I/O Space, BA=0x00000000E0000000, size=0x1000
Memory I/O Space, BA=0x00000000FED1C000
Port I/O Space, BA=0x290
Port I/O Space, BA=0x2E
