Hello guys just wanted your personal opinion if everything here seems good for you guys, this is my first overclock, original is 2.83 Ghz and i overclocked it to 3.4Ghz.
So i wanted to know if you guys think this will last without any problems.
My system specifications:
CPU: Intel 2 Quad Q9550 2.83 Ghz
MotherBoard: Gigabyte GA-EP45-EXTREME
GPU: GeForce GTS 450 1GB OC GDDR5 PCIe GV-N450OC-1GI
RAM: 2x2GB 1600MHz DDR3 M2P2G64CB8HC9N-DG
2x2GB 1333Mhz DDR3 PC3-10700H
How i overclocked it in bios what values i put:
The multiplier is at 8.5x (didnt change that), FBS - 400 Mhz, CPU Vcore was set to 1.135V i put it to 1.150V but somehow here in CPU-Z it says its 1.072V, Up-d the CPU Termination by 0.02V MCH by 0.04V and DRAM Voltage by 0.04V, thats all bios settings i changed.
Yesterday i ran Prime-95 for 7hours no errors poped up and it was green all the time i suppose that means its stable, did intel burn 10 tests on Maximum stress and the highest temp i ever had was 69 °C on the first core all others were up to 60 °C max.
Since this is my first overclock i wanted some opinion from you guys did i do everything good, should i change something in the bios or do some tests, cause to be honest i saw a lot of posts and videos how to overclock all of them had trouble doing it i changed only few values and i guess 69 °C on 100% load is good, thank you for your time
Oh and yeah my GPU Temp is now 57 °C when im doing some hard stuff is it maybe effected from overclock as far as i remember before it didnt go above 50°C is that normal temperature?
