- Apr 26, 2017
- Beloit, Wisconsin
Ok, first question. And this may indicate that i lost the silicone lottery.
Intel I7 4790 in a Z97-E/USB 3.1 using a Noctua D15 cooler with 1 fan not two on the tower, two wouldn't fit
I started using the motherboards inbuild overclocking software. If i set it to the lowest setting, for desktop type stuff it overclocked a bit. My CPU was like 4036 or something like that.
But if i tried to go the next level up it would not even load.
On top of this issue m SSD only is accessable if set as raid on the motherboard setting. I haven't tried IDE or Disabled atm. It I set it to AHCI it says it can't access that drive, but putting it on Raid it works. It's the old Drive except the DVD player.
