Ishi_the_FIshi
- Jun 7, 2016
So, this will literally be the first time I overclock a processor, and I would like all the moon tips along with some safe overclock settings to get to around 3.5 out of my 930.
Hello ishi,
Check out this guide: http://www.overclockers.com/3-step-guide-overclock-core-i3-i5-i7/
It is the definitive resource for 1st gen i7'sI was able to get several 920's up to 4ghz, and my trusty old 980x is still kicking it at 4.2.
If you ahve any questions along the way, I am sure they someone will have some insight.
What speed is your ram running it? did you have to "overclock it" to actually get it to higher speeds? I ask because this comes from the same family as a Xeon i recently starting playing with and it only recognizes up to 1066mhz ram according to intel ARK (i7-930 reports the same support).
