- Oct 9, 2005
I have some advice to ask of the forum. I recently upgraded my pc with an ASUS P5P800 mobo, an Intel Pentium 4 630 3.0ghz processor, and a Thermaltake CL-P0092 SILENT HP P4 775 LGA775 COOLER using Arctic Silver compound. I have 2 sticks of Kingston Valueram at 512mb each DDR400 PC3200 ram and a Chaintech Geforce 6200 with 256mb video ram. I opted for the thermaltake cooler with copper base and heatpipes for the obvious reasons, the stock aluminum intel heatsink leave much to be desired and I'd like to oc this puppy.
I've tried oc'ing the motherboard with the bios's auto settings like 5%, 10%, 20%, and so on. Not actually changing the vcores or anything, and I did the 10% which put it at around 3.3 ghz. It ran fine for a while, until my onboard Marvell gigabit ethernet started to malfunction and losing internet connectivity and even vanishing from device manager. I then did it manually after receiving some advice I upped the vcore to 1.41 volts. That seemed to solve the ethernet problem, but I noticed the temp during heavy loads reached nearly 70 degrees celcius with standard intel cooling fan and around 58 degrees celcius under normal load. I have not received the new thermaltake yet, but will be getting it on Tuesday.
Ok finally to my question, I'd like to oc this P4 630, but I don't want to overdo it, I want to remain 100% stable while squeezing some extra processing juice from it. Any recommendations? Please include with your suggestions all the necessary bios changes I'll need to make including vcore, agp voltage, front size bus mhz, memory settings and voltages, etc...Anything and everything I'd have to modify to complete the overclock. Also, in a gaming environment, should I leave Hyperthreading enabled or should I disable it?
Any suggestions anyone could offer would be greatly appreciated! Thank you in advance.
