- Jul 8, 2012
So I have a i5-4690k... Was able to get it stable at vcore 1.2v at 4.4ghz, all cores...
thinking I could go higher with more volts but I'm happy with that as while stressing my temps are as high as I want them(82C the highest seen with prime)... and this is a 24/7 config.
I currently set cores to 4.4, 4.4, 4.6, 4.6 Thinking while not try to increase per core performance...
I don't see much info on testing for stability for these type of configs... prime at small FFT is stable with all 4 cores selected.. been also running prime selecting 2 and 3 cores to try to force those per core turbos..
Do you believe this is the best way to test stability?
Not sure how much real gains I'll see for doing this but thought why not if stable. Maybe i'll see if I can go 4.4, 4.5, 4.6, 4.7 next or something.
Thanks
Thanks
