Overclocking problems and WD and IBM Harddrives
rlemieux
Cyber Deal King
The Big Easy
Ok here is the facts.
Had system running stable at 2.138 with 118fsb. Then had fatal error on hard drive. So, I thought the hard drive was bad. Call WD and they sent me out a new one, cause mine is under waranty.
Intstalled the new one, with my old WD as a slave. Transfered all my data. Decided I would try to overclock it again. Got to 118fsb and 2.138. Very stable, no heat probs. Let it run like that with both WD's for about 6 hours. Decided everything was fine, would uninstall the old WD and put in my IBM, which is just a backup drive. Shut down computer, pulled out the old WD and put in the IBM as a slave. Rebooted, FATAL ERROR, BLUE SCREEN. Had to bump my CPU back down to stock and reintall Windows XP.
Windows installed fine, now I am at stock speeds and everything is ok.
What could have caused this, btw the WD and the IBM are ATA66 7200RPM Drives.
AntiHeiss
Senior Member
Texas
Well, I may be going out on a limb here but I would say overclocking an ATA66 hard drive to 118FSB might be your problem. Hard drives don't like high FSB's because it makes them work a lot harder. Hard drives just get to a certain speed where they produce too much heat for themselves and just generally give up and produce errors. And I would probably be willing to say that if you dropped your FSB a couple (few) points, you might not have that problem. The IBM drive may be your problem actually....the WD drive can do just fine by itself, but when it has a slower drive on the chain and its overclocked they just get ticked at each other. :) Just keep playing with it and figure it out. I'll bet you'll have a much more stable system if you let it relax a little bit.
Good luck
explorer
Ohio
I would look into a maxtor adrive, I have an ata 133 20 gig and I can run perfectly with a fsb in the 170's.
