Overclocking Problems
Cooler666
Disabled
I overclocked my P4 Northwood 1.8A processor to 2.1Ghz at FSB 117 and when i start the computer the first time I can go into Windows XP and everything is fine, but when I shutdown the computer and open it again it will not boot to Windows XP.
I tried upping the voltage up to 1.625 and it does the same thing.
I tried FSB's from 117 down to 113 and same thing.
At 112 FSB (@2Ghz) that works fine but i get lockups inside Windows XP sometimes.
Could this be because of my power supply?
It is a Aopen 300W which i got with my case.
My load temperatures are around 48Celcius when i overclock, just one or two degrees higher than when its not overclocked. When it's not overclocked there are no lockups.
I have the Zalman Sunflower and two fans blowing in on it (better temps i checked that blowing out).
(Motherboard Abit TH7II-Raid with 512 Samsung RDRAM)
Tell me what you think, thanks.
theres the possibility its because of the PSU..get a program to monitor your +5v and +12v lines and see if they are dropping or fluctuating badly...its possible it could also be because your northbridge..not the cpu..is overheating, is it actively cooled?
~jeff~
My +5V line flactuates between: 4.92 and 4.95
My +12V line flactuates between: 11.86 and 11.98
is this ok?
is this ok?
This looks fine, but are you sure you are not missing
dips in the voltage when your HDD or CDROM drives
kick in?
