- Jul 14, 2003
So after a failed 771-775 mod on my brother's system (the Xeon x5470 would post and load windows but would randomly bsod like mad, regardless of what voltage I set it at), I decided to find him a q9650 and bump it to 3.33 or better to match or beat that xeon. Didn't like their prices on ebay and saw the q9550s aren't a whole lot slower but cost a whole lot less. Im thinking, maybe I can reach the same OC I was hoping for with the q9650.
So I came across this link which recommends (apparently) I use DDR2-1066 ram for the OC due to FSB constraints and limits of DDR2-800.
http://www.scan.co.uk/images/shops/intel/Intel_Q9550_Core_2_Quad_basic_overclocking_guide.pdf
Bumping the FSB to 400mhz is what will get me to 3.4ghz on the CPU, but apparently that's the limit of the DDR2-800. Should I be worried about stability issues or voltage issues on the ram when attempting to reach 400mhz? I don't see myself trying to go any further than that (which I don't think I can anyways with that RAM) so im just wondering if having DDR2-800 will be nuisance at this time.
System specs:
q6600 @ 2.4ghz (I tried OCing it, it isn't the good stepping and doesn't go very far).
6gb DDR2-800 (hodgepodged from spares: 2x2gb OCZ Reaper, 1gb PNY, 1gb Patriot. Dual channel Interleaved mode preserved, however so that's good)
Nvidia GTX 460 GPU
Asus P5q-SE/R mobo
Cooler Master Hyper T4 Cooler
Corsair Carbide 400r case
Thanks!
System specs:
Nvidia GTX 460 GPU
Asus P5q-SE/R mobo
Thanks!
