Impulse The Fox
- May 10, 2017
I recently have gotten a motherboard (Prime B350-PLUS) with a CPU (AMD Ryzen 5 1600) and some RAM (2x4GB 3000MHz, Corsair Vengeance).
On default my motherboard sets the RAM frequency to 2133MHz and the voltage to 1.2V. If I try to change the frequency to 2933MHz and the voltage to 1.35V, it boots a few times with 3 short beeps, then once with 1 short beep, then again once with 1 short beep to say "Overclocking has failed.".
What am I doing wrong? Is the voltage too low?
BTW: When I try to use the preset RAM overclocking profile, it just boots once, without any beeps. The fans turn on but everything else remains unpowered and dark. On a restart the same thing happens. I waited for 2 minutes but nothing happened. I had to remove the CMOS and put it in again to fix it. Then everything again runs fine, but only on the default 2133MHz - 1.2V. I've got the latest BIOS update and my RAM sticks are in the recommended slots.
How could I achieve my desired speed? What could be wrong?
