Hi everyone,
I am new to the forum and never was really involved in to posting anything myself before, so please sorry in advance in case I am doing anything wrong.
Back to the topic, I just built my new system jumping from x58 Bloomfield i7 960 on to z170 Skylake 6700k. My first overclocking experience with Bloomfield was relatively smooth other then I got a mediocre chip. So I was able to push it to 4.2 on water with 1.325 in bios without V-droop with temps around 60s for the chip and 70`s for cores under max load.
Now, considering Bloomfield is soo far behind in terms of cpu architecture, there is a bunch of new features and other things to consider while overclocking. Things like Dynamic V-core for instance, different LLC states, power-saving features etc etc. I know these features (at least some of them) have been around for a while already and I know these things quite well, in terms of how these features work and what kind of effect they have on a system, however this makes me a bit confused. I am not sure where to start my overclock considering the difference in platforms.
Therefore I am here and would like to get some input from you good people, who are on a newer gen platforms and know what they are doing.
Basically my main points / questions are:
1. How different the overclocking process is comparing to, say, Bloomfield vs Haswell (or is it more relevant to compare Bloomfield vs Skylake considering it has unlocked blk this time around)?
2. What are the new things to consider (again comparing different platforms)
2. Overclocking blk vs higher multiplier
3. Anything important I need to know re Uncore Frequency (for instance with Bloomfield, UF was twice the ram multiplier)
4. Should I use LCC / Vdroop-off? If yes, what states should I be considering the most.
5. Keep Speedstep enabled and set up dynamic vcore, or disabling it all together
6. Cpu turbo (on vs off)?
I believe I have covered most of my concerns here and I very hope everything will make sense (apologies if it does not, as it has been a while since my last overclock and I might have forgotten some terms etc.)
Any help is very appreciated. Thanks in advance.
Also please note, I did not have a chance to have a look in to newer bios (in my case its Asus z170), so I have no idea what to expect. I was using Evga FTW3 on my x58 system.
(system specs: z170 Asus Maximus 8 Hero, i7 6700k, Thermaltake Water 3.0 Ultimate - cpu cooling, Vengeance LPX 16GB (2x4GB)x2 DDR4 3200MHz C16, Nvidia GTX Titan X, Antec HCP-1000 Platinum PSU)
