Hello everyone,
Background: After having some fun with overclocking the CPU and getting good results, I thought that now might be a good time to overclock my GPU as well.
My GPU is the Zotac 680 GTX, no factory OC, and no unique cooler (just the stock blower). The blower thing makes plenty of noise, but I can live with it. I have ensured good air circulation around the GPU: There's a side fan, an intake fan right near the entrance to the blower, and another intake fan right above the GPU.
The Overclock: So I downloaded MSI Afterburner, created a custom fan profile, and then started playing around with the configurations. The first thing I've done is to increase the "Power Limit" slider to the max, which is 132%. Then I increased the Core clock by +100MHz, and the Memory clock by +300MHz. The gains: About 8 more FPS on Furmark and 3-5 more FPS on Witcher 3. Not huge by any means, but an improvement.
In order to test the stability of the new GPU configuration, I went on ahead and ran Valley benchmark for over an hour. It didn't crash or anything like that, and the temperatures were somewhere between 72-74c. Immediately after that, I seized the (Heat
) momentum and ran FurMark for 20 minutes or so, and the temperature peaked at 78-79c. Again, no crashes.
I played Witcher 3 for about an hour or so, and the GPU temperature was again between 72-74c. Ran great, no crashing.
My Questions:
1. Is this overclock considered "Mild", or am I pushing the card to it's limits?
2. Are there any major risks in what I've done? Am I more likely to wake up one morning with a bricked GPU, or have a scary crash during a game?
3. Were my stability tests reasonable, or was there anything else I should have done?
4. Are those temperatures OK for the 680 GTX?
Thanks for the help! A newbie
My Questions:
