Hey peeps, I was bored this morning and decided to try to OC my duron. Here is the info on it....
Duron 1.1Ghz ASHHA
Stock volts = 1.75
unlocked currently @ 9x
anything else?
Ok, so I have been running this puppy at 1.2Ghz for a while now, kinda like a burn in. Seemed to work to, because this chip used to crap out at 1.23Ghz, but I am typing this up at 1.26Ghz. Here is what I have now....
1260Mhz
140 FSB x 9
1.82v's
I wanted to know what the max safe voltage is for a Duron morgan. The temps are...
idle = 45C
max = 49C
Do you think I could SAFELY raise the Vcore some more? I am getting an AXP 1800+ in about a week, so I just wanted to see how high this thing can really go. As for the FSB, I don't expect to get that very high, mainly because this Gigabyte is notorious for corrupting your HDD at high FSB's. Also, if the system reboots during a sandra memory bench, would that be caused by the ram or CPU? I bumped the Vdimm up to 2.6v's but I haven't tried the bench again yet....what would a safe max Vdimm be?
Duron 1.1Ghz ASHHA
Stock volts = 1.75
anything else?
1260Mhz
140 FSB x 9
1.82v's
idle = 45C
max = 49C
