Overclocking Titan XP-suggested settings
Johan45
Does the fan speed up through MSI with it set to max on manual?
Johan45
What brand is the card?
No, guessing I need a fan controller chip
The card controls the fan so if it's not working coulb be a card issue or SW issue. Will it speed up at all during use?
JrClocker
AKA: JrMiyagi
I've been using the EVGA software to OC my Titan X Ps. Before I did my AIO mod, I had the fan curve like this:
75 C = 100%
70 C = 90%
65 C = 80%
60 C = 70%
50 C and below = 50%
The fan is REAL loud at 100%...but that's what it takes if you are going to OC the card (check out my AIO mod in the NVIDIA section).
My OC settings for each card are:
GPU: +200 MHz
Memory: + 100 MHz (can do more, but not really interested in memory overclock for my use)
Power Target: 120%
Temp target: 86 C
In the stock cooler, I'd get about 1950 MHZ sustained GPU frequency at 80-ish C.
With the AIO mod, I get 2075 to 2125 at 45 C-ish...and quiet!
Edit: forgot to add that the voltage slider is at 50% also
