- Nov 20, 2001
- Fort Wayne, Indiana
As most of you know... I have an 800e on an abit slotket III. These are running on an Asus P3V4X.
Now the problem. I can run 120 FSB no problem... with only a .05 bump in vcore and its stable (1.75). In order to run at 124 FSB I need to up it to 1.85 to even make it to the desktop.
I'm currently running at 124 FSB with 1/4 divider and all... but I can't shut down the comp and then boot at this speed. I can at 120... but in order to get to 124 I need to boot at 120 or lower... then enter the bios and set the vcore to 1.85, save changes and restart, boot so that the vcore changes (doesnt change until AFTER post) then reboot and change the FSB.
If I just reboot It goes without a hitch... but if I shutdown and then press the power button... no post... I have to press the power button and hold it until it turns off... then power up and it will boot at 66 FSB and default voltage... causing me to go through this hole cycle again. It's completely stable... idle temp is 29 C.
Help please
Help please
