Hello everybody!
This is my first post in this forum and I'm looking forward to some help.
These are my system specs:
AMD Phenom II X3 720 BE
ASUS M4A78T-E
XFX 9800GT
1x2GB Transcend DDR3 1333Mhz
OCZ Vendetta 2 CPU Cooler
Cooler Master 600W PSU
I overclocked the processor to 3.6GHz stable at 1.525V. I used the AMD Overdrive Utility. This is where I hit a wall. No matter how much more I increased the CPU Voltage (went up to 1.55V) I could not obtain a higher stable OC.
Then I came across Dolk's guide to the Phenom II. He mentioned that it's necessary to increase the CPU NB frequency when increasing the CPU speed. I had not done that before and so I felt that maybe this was the reason I was failing to achieve a better OC. I increased the CPU NB to 2200MHz from the stock 2000MHz. However, I still can't get up to 3.7GHz. My temps on load stay under 50c.
Also, I haven't done anything with my RAM settings. Overdrive shows that my RAM speed is 667MHz. I presume that it means it's running at the stock speed since it's DDR3 1333MHz. The DDR Voltage is set at 1.6V.
Do I need to alter my RAM settings and voltage for a higher stable overclock?
Any help is greatly appreciated.
ASUS M4A78T-E
XFX 9800GT
