Hey everybody
I've got a question that you hard-core overclockers may know the answer to;
These are my specs:
Athlon T-bird 800 @ 1 gHz ( 100mHzx10)
ASUS A7V
256 MB 100 mHz DIMMS CAS/RAS2
Case with 1 power transfo fan
2 case fans on the rear blowing air out
1 fan on the front blowing air in
Cooler Master CPU cooler fan
cooling paste between the CPU and grid ( not too much)
I had this problem:
standard CPU temp in idle with ASUSprob read
CPU @52°C
Mainboard at 32°C
This was no problem to keep the system stable.
However, whenever I'd run a CPU intensive application , CPU temp 'd go up to 57°C which appearantly is crash temp. for this CPU.
Now i'm not into watercooling ( I don't know a thing about it and I don't wanna either) but I thought;
what use is there in having any cooler blow air onto the CPU cooler if the air itself is hot? So, if I could get the CPU to blow in cooler air from outside the case straight onto the CPU grid, it should cool things down, right?
Wrong, it seems.
I have placed a plastic tube in the case from the front to the CPU. On the front, it is placed on the fan that blows air into the tube ( completely sealed so that it takes in only outside air and that it goes into the tube alone.)
Then it runs to the CPU where the cooler master fan again blows the air from the tube ( and only the tube) to the cooler grid.
However, to my astonishement, the CPU now reads
54°C with ASUS probe
and mainboard 34°C.
I don't get it, any ideas on what may be wrong with it?
Would blowing air OUT increase usefulness? ( so invert both CPU and case fans)?
Below is a photo of it ( or a link if this fails)
or
These are my specs:
ASUS A7V
I had this problem:
CPU @52°C
Mainboard at 32°C
Wrong, it seems.
and mainboard 34°C.
or
