I've just bought a Jetway 920BF and a celeron 766 processor.
Until the whole lot arrived I wasn't even thinking about overclocking, and the unit was only for a second machine, so the specs were ok...
After fitting the processor with stock heatsink and some arctic silver compound I booted up, installed win98 and all the apps that came on the motherboard CD
The healthmonitor shows a cpu voltage of ~1.93v and a temperature of around 52c (125.6f)
Can anyone recommend how I can go about lowering the voltage (there dosent seem to be any jumpers or settings in the bios)
After running it for 10-15 mins I decided to see what it would overclock to, I got up to 83MHz FSB and bottled out ;o)
Running along nice and smooth, no bsod's at 954MHz although under load it did heat up a little more, to around 58c (scary... I was ready to shut it down)
Is the temperature/voltage going to be a problem, and if so, what should I do?
pete
pete
