Overkill? Or a good case to play with.
Lopus
At first I was looking into getting the new Koolance case, but last moment I changed my mind. So then I decide I want a case where I have plenty of room to put in a good solid water cooling system.
I will have 5 hard drives, and plan to overclock a little bit, nothing monsterous or anything. So here is the case I was looking into:
http://www.directron.com/fs2200b.html
Overkill? Or is there such a thing?
Starfoxer
World's Biggest E-Thug
USA
that seems goof. plenty of room and the heat dispertion
should be good. especially when you have 5 HDD's creating
all that heat.
make sure to have HDD coolers or some type of fan blowing
on your HDD for those seem to create lots of heat.
Starfoxer
USA
oh i forgot, there is no such thing as overkill
and
WELCOME TO THE FORUMS!!!
zoopa_man
NY where the cows out number the people
Overkill ?? what's that ?? Hehe I'm a firm believer in having an enormous case. I've got a full tower case and it's filled to the brim.
In the end it's your decision. I would keep in mind a few things
-future expansion planns
-will it fit in the space where you want to put it
-can you stand to look at it
-extra places for fans and added cooling
-sturdyness nothing like a wimpy case
By looking at the link you showed us That looks like a cool case. I think you should fare well with it. ther's lots of open air space which is a good thing. it allows the air to circulate around to keep things cooled off. there's 14 5 1/4 bays LOL that's enough and it will take 7 80mm fans...that's more then enough to keep all those hard drives happy. Looks like a good choice to me...as long as your happy with the way it looks Go for it.
Check out ebay to see what they have for full tower cases...that might be easier on the wallet...I just saw the price on that case OUCH that's a lot of lunch money.
And one more thing.....WELCOME TO THE FORUMS
BigRed
Caffinated Member
Mount Vernon, WA
Overkill? *points at his hdd space* whats that? :beer:
when buying a case ALWAYS buy it larger than what you need, cuz you will probably need it in the future. i wish i bought the full tower chemning case, cuz i wanna add a few things to mine but theres no room :( oh well. it still looks damn sexy :D
L
Lopus
Wow, thanks for the great welcome everyone! :D
I'm pretty sure this is the case I'm going to go with. Plenty of room for any kind of upgrade I want to put in it, or mod I'd like to do.
Think I may try and put a window in the side and paint it a different color though.
Thanks again for the suggestions and comments!!
RangerJoe
All that is Man!
Stillwater, Oklahoma
does anyone know where i could happen to find a HUGE!!! full tower AT case? my summer cooling project will be going in it, and i need as big as you can get (at a reasonable price) please HELP
rivercom9
Sacramento, CA
Anyone know where I can get a case like the one that Lopus was showing only in black and cheaper? Lopus, thats a great case, especially if you will want to go water cooling and have all them hard drives.
stool
Senior Member
Albany, NY
First thing you want to do is check out the inside before you buy. These cubes aren't just a wide-open box, there are two separate sides, kind of like two midtowers put together. You have the mobo, and intake fans, sometimes a couple of drive cages on one side, then the PSU and drive cages on the other.
rivercom,
For a couple of better deals on server cubes, look;
here , check out A9891, CK1100 and YY0221
and here
Most are about $200 cheaper than the one from directron.
dvj81
Phoenix
rivercom9 Anyone know where I can get a case like the one that Lopus was showing only in black and cheaper?
Rivercom9, try the link directron for a black server case for $179. This includes a generic 300watt PSU and 3 fans. I just bought. It looks to be almost identical to the one at Case Outlet model YY-0221 but that is $199.
Directron Server case YY0221BK
But hey why not get a :eek: premade :eek: overclocking case? Check it out!! :eek:
REAL overclocking case from Enermax
