Wierd...
TMPIN1 IIRC, is the socket temperature, which is usually about 8-10C hooter than actual CPU temps. You can use that as a very rough guide.
I had HwMonitor not read the voltages for some reason once. Installing a new version fixed it. Try that.
Openhardware monitor was able to read some voltages when hwmonitor couldn't so try OpenHardware monitor too.
You are not reading temperatures on the core because you have core unlock enabled. It is a side effect. Disable it. There are no additional cores to unlock on that chip.
That's an odd side effect Scott... Guess it goes with Gigabyte's BIOS's? Crappy?You are not reading temperatures on the core because you have core unlock enabled. It is a side effect. Disable it. There are no additional cores to unlock on that chip.
Well jax, guess this means you need to see how well your cooler is holding up! Prime95 time!
Try lowing the primaries yes. 9-9-9-26 are the primary timings on your RAM.Well all I really ended up doing was increasing the FSB. Never ended up touching the voltage or memory timing. I'm fine with 3.5 TBH and don't care to touch the voltage just to eek out some more but can someone look at those memory timings in #23 and make sure that's OK. Last couple seem pretty high. Should I bother bringing them down some?
Lower the fist value (known as CAS) by one and run memtest to test for errors. If you do find an error, you can safely raise the RAM voltage to 1.65v without any harm. You might be able to get something like 8-9-8-24 on those sticks But I don't think you can get them any tighter...
Make sure you are stable before booting up Windows. Unstable RAM will eventually cause hard disk corruption basically needing a reinstall of Windows..
Honestly, for the most part you won't notice any difference. Unless you are going from 11-11-11-28 to 8-8-8-24 you won't really see it. I would much rather have slower, stable RAM than tighter RAM that might be a bit "iffy".
