Overlocking HD 7970 (R9 280X)
M4rt4Z
Hello,
I tried to overclock my hd7970 memory, when I add 5mhz and I want to startup Google Chrome or play video in chrome my display crashes, I must hard reset. In benchmark It's ok, I tried 1725mhz and I got 993 points in heaven benchmark 4.0 (all on max, Full HD).
So I tried bios of R9 280X, where is 1550mhz on memory (On HD 7970 was 1500mhz), and It works OK! But still, when I try to add some mhz... same problem. So I want to try overlock memory through bios, I downloaded software called VBE7, but It can affect only the legacy bios, UEFI part will be disabled.
What it means? Will I lose fast boot, UEFI environment in bios of MB, or I heard I will must reinstal OS??
Thanks
M
M4rt4Z
Flash back the 7970 bios and use trixx modded. It has memory voltage setting (you can go up to 1.65v for GDDR voltage). You should be able to squeeze 100 to 200MHz.
Trixx 4.4.0b modded enclosed.
Already tried, same result. I can add voltage, but I add 5mhz and it crashes when I try open browser. Tried different drivers and bioses.
M
M4rt4Z
No one knows what can happen after disabling UEFI on GPU bios? :(
Itachiii
Can you give us a full spec of your card? Maker, how much voltage you are currently throwing at it, clocks, everything.
