p3 800eb@900 what should voltage be?
To reach 900 you probably woundn´t need to rise the voltage... Unless you notice instability, in this case check the Ram and videocard too... ;-)
For either a slot or socket p3 800eb the spec voltage is 1.65v...so 1.7v is a good choice but not really needed unless you have stability problems...which can be caused by generic ram or tempramental vid. cards. Remember that if you up the core voltage then your generating more heat...
