Newbie_Doo (Apr 26, 2001 09:18 p.m.):
Fear O. Carpet (Apr 26, 2001 12:26 a.m.):
I am new to overclocking and am sort of feeling things out at the moment. I have an ASUS P3B-F, a PIII 600 with a golden orb hs and crappy PC100 RAM which is presumably what's preventing clocking above 115. At any rate, I fished through the CPU database and have wandered into this forum and have noticed that everyone (even other people with the same CPU / Mobo) has their Vcore set below 2.0V... In my BIOS, the lowest option is 2.05V and not knowing any better I set it to 2.10V a while ago, but it actually winds up around 2.16 - 2.20V. How are people setting sub 2.05V on P3B-F boards and am I risking having to remove my proc with a paper towel at 2.10V?
Let's take this one step at a time...FIRST go
HERE and download the latest BIOS to a floppy with the Aflash program. your board has an older BIOS revision that DOES NOT SUPPORT the coppermine Vcores. Do this on a different machine before you fry that poor chip.
You are risking that chip every second it is running at 2.16-2.20v.
Boot your machine with the flash floppy, following the instructions that ASUS gave you when you downloaded the BIOS, and flash the BIOS to the newer version that supports the lower Vcores.
Once you have the lower voltages, drop down to something reasonable like 1.65v and slowly inch up as you raise speed, but not until you either put some Arctic Silver on that heatsink, or get a better heatsink and use some AS with the better one. The Golden Orb is barely adequate for the PIII-600 at default, much less overclocked.
After you have done these things, come back here and post your component setup so we can go from there. DO THE BIOS REVISION RIGHT NOW.
OK, I ran Aflash and revised my BIOS to 1006, which it says supports coppermine Vcores, PIII 850s and what not... I still don't have the option to drop below 2.05V. Here some info on my 'puter if that'll help:
CPU:
Intel Pentium III; Family 6; Model 7; Core Stepping kC0; Technology 0.25 micro; Stepping 3; Brand ID 0; Package, Slot 1 SECC2; Core Voltage 2.11v; Cpu Freq 601.4; Clock Mult 100.2; Original CPU/FSB, 600/100; L1 D-Cache 16kb; L1 l-Cache 16kb; L2 Cache 512kb; L2 Latency 1; L2 Freq 300.7; L2/Core 1/2
On an ASUS FB3-F BIOS rev 1006 (05/16/00) with a 256mb PC133 DIMM
Also, I'm aquiring a PIII 850E from a friend's upgrade- should I worry about sticking it on this board until I get the Vcore thing sorted out?
Tanks again.
