p3v4x + 700E
kevern
buying a p3v4x With 700E fc-pga
And a iwill slocket II
What can I get up to on this board
Using pc133 sdram
Coppermine cores usually run out around 950-1000. A few better and worse than this. Beyond these guidelines, it's a crapshoot. The amount of cooling you provide will play a major role in the ultimate speed.
this is an answer I've given b4...........
The only way to find out is to try, and then find out.
Expect to get a 133Mhz FSB and 933Mhz. I had that out of mine no sweat b4 I had to sell it to fund a binge.
you can check the database at the beginning of this site too. lots of info, ment to answer questions like this one.
The P3V4X is very finicky about slotkets. I'd ONLY advise using an Asus S370-133 ot S370-DL on that board. With such a slotket, the cB0 P3-700Es tend to hit 933 MHz with air cooling and little or no vltage changes.
I run a P3-700E (week 20 flipchip from Malaysia, retail, cB0 stepping) on my P3V4X with an Asus S370-133. My processor's running all day every day @ 1035 MHz thanks to 80-watt Peltier module (a TE Dist. ICE-74) and no-reservoir watercooling. (Processor temp is 5-7 deg. C at all times, and in Windows 2000 with its built-in HLT-on-idle the temp drops to -12 deg. C if I don't run something like SETI@home in the background!)
oO
